To start integrating Pabbly, Pabbly Chat Flow, CSV, and YouTube, you first need to access Pabbly Connect. Open your web browser and navigate to pabbly.com/chatflow to reach the Pabbly Chat Flow homepage.
If you are a new user, click on “Sign Up for Free” to create an account. Existing users can simply sign in. After logging in, you will see all Pabbly applications available in your dashboard, including Pabbly Connect.
2. Setting Up a Broadcast in Pabbly Chat Flow
After accessing Pabbly Connect, you will want to set up a broadcast to send messages. Click on “Access Now” for Pabbly Chat Flow to enter the dashboard. Here, you can manage your WhatsApp number and prepare for the broadcast.
- Go to the Broadcast section.
- Select “Add New Broadcast”.
- Choose “Broadcast Campaign” as the type.
Next, name your broadcast (e.g., “New Jewelry Offer”). You can select an existing contact list or upload a CSV file containing your contacts. If you choose to upload a CSV, click on the “Import” button to create a new contact list.
3. Customizing Your Broadcast Message
With your broadcast set up in Pabbly Connect, it’s time to customize your message. You can either use a pre-approved template or create a new message. If using a template, select it from the dropdown menu.
To make your message more engaging, you can upload images and personalize the content. If you prefer to create a new message, type it in the message field and see a preview on the right side.
- Select the template you want to use.
- Upload any images to enhance your message.
- Test your message by sending it to your WhatsApp number.
Once satisfied with your message, you can proceed to schedule the broadcast or send it immediately.
4. Scheduling Your Broadcast
In this step, you will decide when to send your broadcast using Pabbly Connect. If you want to send it immediately, select “No” for scheduling. For future dates, select “Yes” and choose the desired date and time.
Ensure that the date and time are set for the future; otherwise, the broadcast will send immediately to all contacts. You can also enable automatic retries for failed contacts, specifying how many attempts should be made.
After setting up your schedule, you will see a confirmation that the broadcast has been successfully scheduled, allowing you to track its statistics later.
5. Tracking Broadcast Results in Pabbly Connect
After your broadcast has been sent, you can track its performance through Pabbly Connect. This feature allows you to see how many messages were sent, delivered, read, pending, and failed.
Additionally, you can resend the broadcast to any valid failed contacts, ensuring that your message reaches the intended audience. This tracking helps you analyze the effectiveness of your campaigns and make necessary adjustments for future broadcasts.
With these simple steps, you can effectively use Pabbly Connect to integrate Pabbly, Pabbly Chat Flow, CSV, and YouTube for your marketing needs.
In this tutorial, we explored how to use Pabbly Connect to integrate Pabbly, Pabbly Chat Flow, CSV, and YouTube. By following these steps, you can efficiently set up broadcasts and enhance your communication strategy.
