To promote bulk offers on WhatsApp for your supermarket, the first step is accessing Pabbly Connect. Open your browser and go to the Pabbly website to create your account.
Once you log in, navigate to the dashboard where you can manage your integrations. Ensure that you have your WhatsApp number linked to your Pabbly account for seamless communication.
2. Setting Up Pabbly Chatbot for Bulk Offers
In this section, we will configure Pabbly Chatbot to send personalized offers. From the dashboard, select the option for broadcasting messages.
- Choose the broadcast option from the left sidebar.
- Set the type of broadcast as a campaign.
- Name your broadcast, for example, “Big Store Offer”.
Next, select the audience you want to target. You can either upload a CSV file with customer details or select from existing contact lists. This setup ensures that your messages reach the intended recipients effectively.
3. Creating Your Broadcast Message in Pabbly Chat Flow
After setting up your audience, it’s time to create the broadcast message using Pabbly Chat Flow. Here, you can customize your message and add variables for personalization.
- Select the message type as a template message.
- Add a personalized greeting using variables.
- Include images or buttons for better engagement.
Once your message is ready, send a test message to ensure everything appears correctly. This step is crucial for verifying that your customers will receive the intended format.
4. Scheduling and Sending Your WhatsApp Broadcast
Once your message is tested, you can schedule the broadcast through Pabbly Connect. Decide whether to send the message immediately or schedule it for a later date.
If scheduling, choose the desired date and time. Pabbly Connect allows you to set up automatic retries for failed messages, ensuring that your broadcast reaches as many customers as possible.
5. Tracking Broadcast Results Using Pabbly Connect
After sending your broadcast, it’s essential to track its performance. Use Pabbly Connect to access detailed statistics about your broadcast.
- View how many messages were delivered, read, or failed.
- Analyze customer engagement through response rates.
This analytics feature helps you refine future campaigns and improve customer engagement with your supermarket’s offers.
By utilizing Pabbly Connect, you can efficiently promote bulk offers on WhatsApp for your supermarket. This step-by-step guide shows how to integrate Pabbly Chatbot and Pabbly Chat Flow to maximize your outreach.
