1. Getting Started with Pabbly Connect
To begin automating your LinkedIn posts, you need to access Pabbly Connect. If you are a new user, open a new tab and search for pabbli.com/connect to reach the Pabbly Connect landing page.
Once there, click on the “Sign Up for Free” button located in the top right corner. This allows you to explore Pabbly Connect with 100 free tasks each month, perfect for testing this automation.
After signing in to Pabbly Connect, click on “Create Workflow” and then choose “Create Using Quick Builder”. Input your prompt to automate LinkedIn posting, such as “Post daily on LinkedIn using Gemini”.
- Select “Schedule Workflow” as your trigger.
- Choose the action from Gemini as “Generate Content”.
- For LinkedIn, select “Share Simple Text”.
After these selections, click on “Approve and Create” to finalize your workflow setup in Pabbly Connect.
3. Scheduling Your Workflow
Next, you need to configure the schedule in Pabbly Connect. Click on the schedule option and set it to run daily at 1 p.m. This ensures your LinkedIn posts are automated without manual effort.
After saving your schedule, proceed to connect Gemini. Click on “Connect” and choose to add a new connection. You will need to input your API token from Google AI Studio to establish this connection.
- Go to Google AI Studio and find the “Get API Key” section.
- Click on “Create API Key” and name it accordingly.
- Copy the generated key and paste it into Pabbly Connect.
Once the key is saved, your connection to Google AI Studio will be established successfully.
4. Generating Content for LinkedIn
With your connections set up, the next step in Pabbly Connect is to generate the content for your LinkedIn post. You will need to enter the prompt that will guide Gemini in creating the content.
After pasting your prompt, select the model and method for content generation. Click on “Save and Send Test Request” to see the generated content based on your input.
- Ensure your prompt is tailored to your LinkedIn audience.
- The generated content will be displayed shortly after your request.
Now that you have your content, it’s time to move forward and connect to LinkedIn.
5. Posting to LinkedIn Using Pabbly Connect
The final step is to connect your LinkedIn account through Pabbly Connect. Click on “Connect” for LinkedIn and select “Add a New Connection”. Ensure your LinkedIn account is logged in to facilitate a seamless connection.
After establishing the connection, you will need to map the content generated by Gemini into the LinkedIn post. Mapping allows dynamic data insertion, ensuring your posts are updated with every workflow run.
- Select the author for the LinkedIn post.
- Map the content generated by Gemini into the post field.
- Choose the visibility settings for your post.
After saving the settings and sending a test request, you will receive confirmation that your post has been successfully published on LinkedIn. You can refresh your LinkedIn profile to see your new automated post.
In this tutorial, we explored how to automate daily LinkedIn posts using Pabbly Connect and Google AI Studio. By following these steps, you can save time and enhance your online presence effortlessly.
