1. Connecting Pabbly Connect with Claude
To start, access Pabbly Connect and navigate to the left sidebar. Here, you will find an option labeled “Customize”. Click on it to proceed.
In the connectors section, search for “Pabbly Connect integration builder”. Select it and click to connect with Claude. You will be redirected to a permissions page where you must click “Allow” to establish the connection.
2. Utilizing Pabbly Connect with ChatGPT
Next, we will integrate Pabbly Connect with ChatGPT. Start by accessing the plugins section on the left sidebar. Here, search for the Pabbly Studio plugin and install it by clicking “Allow”.
- Navigate to the ChatGPT plugins marketplace.
- Search for Pabbly Studio and click on it.
- Install the plugin and allow necessary permissions.
Once installed, you can use ChatGPT to request information from your Pabbly applications. For example, ask it to show your Pabbly Studio apps, and it will respond accordingly.
3. Adding Custom Pabbly Applications
If you want to connect a Pabbly application not listed in the directory, you can add it using the MCP URL. First, navigate to the “Customize” section, then click on “Add” under connectors.
In this section, name your custom connector, for instance, “Pabbly Studio”. You will need to copy the MCP server URL from the Pabbly Studio settings. Paste this URL in the designated field and click “Continue”.
- Access the settings of the Pabbly application you wish to connect.
- Locate the MCP URL and copy it.
- Paste the URL in your custom connector setup.
After pasting the URL, click “Connect” and allow the necessary permissions. Your custom application will now be linked to Pabbly Connect.
4. Creating Workflows in Pabbly Connect
To create a workflow, go back to the Pabbly Connect dashboard and click on “Create Workflow”. This will allow you to build workflows using Claude or ChatGPT.
Select the appropriate MCP URL for the application you want to connect. If integrating with Pabbly Email Marketing, navigate to its app dashboard and find the MCP server URL under settings.
Make sure to use the correct MCP URLs for each application. This ensures that your workflows function seamlessly and all integrations are correctly established.
5. Conclusion
In this tutorial, we explored how to effectively use Pabbly Connect to integrate with AI tools like Claude and ChatGPT. By following the steps outlined, you can enhance your automation processes.
Utilizing Pabbly Email Marketing along with these integrations can further streamline your tasks. Always ensure you are using the correct MCP URLs for your applications to maintain a smooth workflow.
For any questions or feedback regarding this tutorial, feel free to leave a comment below.
