1. Accessing Pabbly Chatflow for WhatsApp Broadcasts
To begin using Pabbly Chatflow, open your browser and visit pabbly.com/chatflow. Here, you can create your account and get started with the broadcast setup.
Once you have logged in, make sure to add your WhatsApp number to your Pabbly Chatflow account. This is crucial as it allows you to send messages through the platform. After that, navigate to the WhatsApp Broadcast section.
2. Setting Up Your WhatsApp Broadcast in Pabbly Chatflow
In the WhatsApp Broadcast section of Pabbly Chatflow, you will set up your broadcast campaign. Start by selecting the broadcast type as “Campaign Broadcast” and name it, for example, “Stream Max Offer”.
- Choose the audience for your broadcast
- Select either a contact list or upload a CSV file with customer details
- Add contacts individually or in bulk
After selecting your audience, you can optimize and filter it. This means excluding contacts you don’t want to send messages to. You can also choose to skip contacts who have had active chats in the last 24 hours.
3. Choosing the Message Type for Your Broadcast
In this step, you will choose the type of message to send through Pabbly Chatflow. You can opt for a regular message or a template message. If you select a template message, ensure it has been pre-approved by Meta.
- Create or select a template from the left menu
- Add any images or media to your message
- Preview your message to ensure it looks correct
Once you have finalized your message, you can send a test message to yourself to confirm everything is set correctly before sending it to your audience.
4. Scheduling Your WhatsApp Broadcast with Pabbly Chatflow
After confirming your message, you can schedule your broadcast in Pabbly Chatflow. Choose whether to send the message immediately or set a specific date and time for later.
If scheduling, select the date and time you want the broadcast to go out. Additionally, enable the option to automatically retry sending messages to contacts if the initial send fails.
5. Viewing Broadcast Statistics in Pabbly Chatflow
Once your broadcast is scheduled, you can monitor its performance using Pabbly Chatflow. After the broadcast has been sent, click on the “View Statistics” button to see the report.
This report will provide insights on delivery rates and engagement, helping you refine future broadcasts. Utilizing Pabbly Chatflow effectively allows for streamlined communication with your audience.
Setting up WhatsApp broadcasts using Pabbly Chatflow simplifies communications. By following these steps, you can efficiently manage your messaging campaigns and enhance customer engagement.
