To create an AI-powered WhatsApp assistant, you first need to access Pabbly Connect. This platform allows seamless integration between WhatsApp and various applications, including AI assistants.
Begin by navigating to the Pabbly Connect website. If you’re a new user, you can sign up for a free account to explore its features. Existing users can simply log in. Once logged in, you will be ready to set up your integration.
2. Setting Up Your WhatsApp Assistant Using Pabbly Connect
After accessing Pabbly Connect, you will need to set up your WhatsApp assistant. This involves creating an AI assistant using Pabbly Chatflow, which is integrated with Pabbly Connect.
- Navigate to the AI assistant page in Pabbly Chatflow.
- Select the instruction type as AI agent.
- Set the temperature for your AI responses to determine creativity.
Once you have configured these settings, you can proceed to define the API key for integration. This key is essential for connecting your AI assistant with Pabbly Connect and enabling it to respond to queries.
3. Creating a Knowledge Base for Your AI Assistant
The next step involves creating a knowledge base that will serve as the brain of your AI assistant. This knowledge base is crucial for providing accurate responses to user queries through Pabbly Connect.
Ensure that your knowledge base includes:
- Business overview and target audience details.
- Service details, pricing structures, and common customer queries.
- Frequently asked questions to guide the AI’s responses.
Your AI assistant will use this information to respond effectively to customer inquiries, significantly reducing manual interactions.
4. Finalizing and Activating Your AI Assistant
After setting up your knowledge base, the next phase is to finalize and activate your AI assistant through Pabbly Connect. This is where you can customize the appearance and functionality of your assistant.
In this section, you can:
- Add header and footer messages for a personalized touch.
- Enable auto-replies for all contacts or specific chats.
>Once these settings are configured, click on the save button to activate your AI assistant. Your assistant is now ready to interact with clients on WhatsApp.
5. Embedding Your AI Assistant on Your Website
Finally, you can embed your AI assistant into your website using Pabbly Connect. This allows users to interact with your assistant directly from your site, enhancing customer experience.
To embed the assistant, simply click on the embed button in Pabbly Chatflow. Copy the provided script code and paste it into your website’s HTML. This integration ensures your assistant is readily available for customer inquiries at all times.
By following these steps, you can successfully create an AI-powered WhatsApp assistant using Pabbly Connect. This integration not only automates customer interactions but also enhances the overall efficiency of your business.
