To start automating Facebook posts, visit Pabbly Connect’s website at Pabbly Connect. This platform enables seamless integration of various applications, including OpenAI. If you are a new user, sign up for free to receive 100 tasks monthly, allowing you to explore automation capabilities.
After signing up, log in to your Pabbly Connect account. Once you are on the dashboard, you can begin creating a workflow. This process does not require any coding skills, making it accessible for everyone.
To create your Facebook posting workflow, click on the “Create Workflow” option and select “Create from Scratch.” Name your workflow something like “OpenAI Creates and Publishes Facebook Posts Automatically.” In this step, you are setting up the automation process using Pabbly Connect.
  • Select the folder for your workflow.
  • Choose “Scheduled by Pabbly” as the trigger application.
  • Set the event to “Scheduled Workflow.” This will allow the workflow to run daily.
Once you have configured these settings, click on the connect option and set the interval to trigger the workflow every day at your preferred time, such as 12:00 PM. Save the step to finalize your trigger settings.
3. Generating Content with OpenAI
Next, you need to generate unique content for your Facebook posts. Add an action step and select OpenAI as the action application. Choose “ChatGPT” as the event to generate your post’s caption. This integration is made possible through Pabbly Connect, which allows you to utilize OpenAI’s capabilities.
To create a connection, you will need an API key from your OpenAI account. Generate a new key and paste it into the provided field in Pabbly Connect. For the model, select GPT 5.4 or any other version you prefer. In the prompt field, enter your request for unique health-related captions.
  • Write a detailed prompt asking OpenAI to create a unique Facebook post every time.
  • Use specific topics like health and wellness to generate relevant content.
Once you’ve entered your prompt, click on the “Save and Send Test Request” button. OpenAI will generate a unique caption based on your input, which will be used in your Facebook post.
4. Generating an Image for the Post
After generating the caption, the next step is to create an image that complements your post. Again, select OpenAI as the action application, but this time choose the event “Generate Image with GPT Image 1.” This step is crucial as it allows Pabbly Connect to automate the image creation process based on the caption generated earlier.
In the prompt field, tailor your request to generate an image that matches the caption. Use the mapped data feature in Pabbly Connect to insert the caption dynamically. This means whenever a new caption is generated, a corresponding image will also be created.
  • Enter a detailed prompt for the image generation.
  • Specify the style, quality, and format of the image.
Click on the “Save and Send Test Request” button to generate the image. After a few seconds, you will receive a URL for the generated image, which will be used in your Facebook post.
5. Posting to Facebook Using Pabbly Connect
With both the caption and image ready, it’s time to create the Facebook post. Add another action step and select Facebook Pages as the action application. Choose the event “Create Page Photo Post.” This integration showcases how Pabbly Connect brings together all elements to automate your posting process.
Connect your Facebook account by clicking on the “Connect with Facebook Pages” option. After granting the necessary permissions, select the page where you want to post, such as your yoga institution page. Then, map the data for the photo URL and description using the previously generated image and caption.
  • Ensure you map the correct image URL and caption for your post.
  • Click on “Send Test Request” to finalize the post.
Once you receive a positive response, refresh your Facebook page to see the new post. This automation setup will now run daily, posting unique content to your Facebook page without any manual effort.
Using Pabbly Connect, you can effortlessly automate the process of creating and publishing Facebook posts daily. This integration with OpenAI allows for unique content generation without any coding skills. Enhance your social media presence with this streamlined automation solution.
