To start automating your product posts on Instagram, first access Pabbly Connect. Go to pabbly.com/connect and create a free account to get 100 tasks each month.
Once logged in, you can easily set up the automation without any coding skills. This is crucial for linking your Shopify store to Instagram seamlessly through Pabbly Connect.
2. Setting Up Webhook on Shopify with Pabbly Connect
To connect Shopify with Pabbly Connect, you need to set up a Webhook. Copy the Webhook URL provided by Pabbly Connect and navigate to your Shopify store.
  • Go to Settings in Shopify.
  • Select Notifications and find the Webhook section.
  • Add a new Webhook for product creation.
  • Paste the copied URL and select JSON format.
Save the Webhook settings. This step ensures that whenever a new product is created in Shopify, the data is sent to Pabbly Connect for further processing.
3. Creating a New Product in Shopify
Now that the Webhook is set up, create a new product in Shopify. Enter the product title, description, and image URL.
Once you save the product, Pabbly Connect will capture the product details through the Webhook. This includes the name, price, and image URL, which are essential for posting to Instagram.
4. Posting to Instagram Using Pabbly Connect
After capturing the product details, it’s time to automate posting on Instagram. Select Instagram for business in Pabbly Connect and connect your account securely.
  • Choose the option to create a new post.
  • Map the product image URL and description from the previous step.
  • Click on Save and Send Test Request.
Once the test request is successful, your product will be posted on your Instagram account automatically. This integration through Pabbly Connect streamlines your social media marketing.
5. Conclusion
By utilizing Pabbly Connect, you can effortlessly automate the posting of new products from Shopify to Instagram. This integration enhances your marketing efforts and saves valuable time.
With the steps outlined above, you can set up this automation quickly and efficiently, allowing you to focus on growing your business.
