1. Introduction to Automating Order Confirmations with Pabbly Connect
Automating order confirmation messages is essential for any Shopify store owner. With Pabbly Connect, you can easily set up this automation to send personalized WhatsApp messages to customers after they place an order.
Using Pabbly Chatflow, you can create a seamless communication channel for your customers. This tutorial will guide you through the process of integrating Shopify with WhatsApp using Pabbly Connect.
2. Setting Up Your Pabbly Connect Account
To start using Pabbly Connect, visit pav.com/connect in your browser. If you’re a new user, sign up for free to get 100 tasks every month. Existing users can simply sign in.
Once logged in, you will see the Pabbly apps dashboard. Click on “Access Now” under Pabbly Connect to enter the main dashboard. Here, you can create workflows to automate your tasks.
3. Creating a Workflow in Pabbly Connect
To set up the automation, you need to create a workflow in Pabbly Connect. Click on “Create from scratch” to start building your workflow. You will be prompted to describe your automation.
For this tutorial, you will enter a prompt such as: “When a new order comes in from Shopify, send a WhatsApp message via Pabbly Chatflow.” After analyzing your request, select the “New Order” trigger from Shopify and the action “Send Text Message” from Pabbly Chatflow.
  • Select “New Order” as the trigger event.
  • Choose “Send Text Message” as the action.
  • Approve and create the workflow.
Once your workflow is set up, you will receive a unique workflow link for future reference. This is how Pabbly Connect streamlines your automation process.
4. Connecting Shopify to Pabbly Connect
To connect your Shopify store with Pabbly Connect, you will need to set up a webhook. Copy the webhook URL provided by Pabbly Connect and log into your Shopify account.
In Shopify, go to “Settings” and then “Notifications”. Here, you can create a new webhook by selecting “Order Creation” as the event and choosing JSON as the format. Paste the copied webhook URL and save the changes.
  • Select “Order Creation” as the event type.
  • Choose JSON as the format for the webhook.
  • Save the webhook settings.
Once the webhook is set up, Pabbly Connect will be ready to receive data whenever a new order is placed in Shopify, making the automation process seamless.
5. Sending WhatsApp Messages with Pabbly Chatflow
After setting up the webhook, you will configure Pabbly Chatflow to send WhatsApp messages. Go back to the Pabbly Connect dashboard and select Pabbly Chatflow as your action application.
You will need to provide an API token from your Pabbly Chatflow account. Access your Chatflow settings, copy the API token, and paste it into Pabbly Connect. Then, map the customer’s WhatsApp number and the message content dynamically.
  • Map the customer’s phone number from the trigger data.
  • Compose the order confirmation message with dynamic fields.
  • Test the message by sending it to your WhatsApp number.
With these steps, Pabbly Connect and Pabbly Chatflow will automatically send personalized WhatsApp messages to your customers, enhancing their shopping experience.
In this tutorial, we demonstrated how to automate Shopify order confirmations using Pabbly Connect and Pabbly Chatflow. By following these steps, you can enhance customer communication and streamline your order management process efficiently.
