To start using Pabbly Connect for WhatsApp broadcasts, first navigate to the Pabbly Chatflow homepage by typing pav.com/chatflow in your browser. This platform allows you to manage communications efficiently.
If you are a new user, click on “Sign up for free” to create an account. Existing users can simply sign in to access their dashboard. Once logged in, you will see various Pabbly applications, including Pabbly Chatflow, which is essential for setting up your WhatsApp broadcasts.
2. Setting Up Your WhatsApp Broadcast with Pabbly Connect
After accessing Pabbly Chatflow, locate the “Broadcast” feature on the left sidebar. This feature allows you to send messages to multiple contacts simultaneously. To start, you need to create a message template that you will use for your broadcast.
- Navigate to the “Templates” section to create your message.
- Make sure your template is approved by Meta to ensure it can be used for broadcasts.
- Once created, go back to the “Broadcast” section to initiate the broadcast.
Now, you can select the “Add Broadcast” button to create a new campaign. Here, you will name your broadcast and select the contact list from which you want to send messages. Remember, using Pabbly Connect streamlines this process, allowing you to manage contacts easily.
3. Importing Contacts to Pabbly Connect
To send WhatsApp messages, you need to import your contacts into Pabbly Connect. If your data is in a Google Sheet, download it as a CSV file. Then, go to the “Contacts” section within Pabbly Chatflow.
Click on the “Add Contact” button to upload your CSV file. Once uploaded, you can create a new contact list or use an existing one. This ensures that your broadcast reaches the right audience efficiently.
4. Creating and Scheduling Your WhatsApp Broadcast
With your contacts ready, return to the “Broadcast” section. Here, select the type of broadcast you want to create. You can either use a pre-approved template or send a regular message. If using a template, select it from the dropdown menu.
Once your message is set, you can test it by sending a test message to your WhatsApp number. This is crucial to ensure that your broadcast appears correctly to recipients. You can also schedule your broadcast for a future date and time, allowing for better planning.
5. Monitoring Broadcast Results with Pabbly Connect
After sending your WhatsApp broadcast, you can monitor its performance using Pabbly Connect. The platform provides statistics on sent, delivered, read, and failed messages, giving you insights into your campaign’s effectiveness.
If needed, you can resend your broadcast to any contacts that did not receive it. This feature ensures that your messages reach all intended recipients, maximizing the impact of your WhatsApp communication.
In this tutorial, we explored how to use Pabbly Connect for efficient WhatsApp broadcasts. By following these steps, you can easily manage your communications and reach your audience effectively. Pabbly Connect simplifies the process, allowing businesses to communicate seamlessly through WhatsApp.
