To start integrating WhatsApp with Pabbly Connect, first, you need to access the platform. Open your browser and search for Pabbly Connect. If you are a new user, click on “Sign Up for Free” to create an account.
Once you are signed up, log in to your Pabbly Connect account. After logging in, you will be directed to the dashboard where you can manage all your integrations effectively.
2. Setting Up WhatsApp Broadcast Using Pabbly Connect
Now that you have accessed Pabbly Connect, it’s time to set up a WhatsApp broadcast. Navigate to the broadcast section and select “Create New Broadcast”. Here, you will define the broadcast name and choose the type of broadcast.
- Select “Broadcast Campaign” as the type.
- Give your broadcast a suitable name.
- Choose the contact list to send the messages.
After setting up these parameters, click on “Next” to move forward. You will now be prompted to select a message type for your broadcast.
3. Creating and Managing Your Contact List in Pabbly Connect
Creating a contact list is essential for sending messages through Pabbly Connect. You can upload contacts manually or import them from a CSV file. To create a new contact list, navigate to the contacts section and click on “Add Contact”.
Once you have added your contacts, you can refine your audience by excluding specific contacts or groups. This ensures that your messages reach only the intended recipients.
- Exclude contacts you do not want to message.
- Select multiple lists if necessary.
With your contact list ready, you can now proceed to customize your message for the broadcast.
4. Customizing Your Message Template in Pabbly Connect
To personalize your messages, you can create a template within Pabbly Connect. Access the template section and draft your message. Use variables to make your message dynamic, ensuring each recipient feels personally addressed.
After drafting your template, select it for the broadcast. You can preview the message to ensure everything looks correct before sending it out. This step is crucial to maintain professionalism and clarity in your communications.
Once satisfied, you can proceed to test the broadcast by sending a message to your own number first. This helps verify that the setup works as intended.
5. Scheduling Your WhatsApp Broadcast with Pabbly Connect
After testing your message, you can schedule your broadcast. In the scheduling options, choose a future date and time for the broadcast to be sent out. Ensure you select a valid future date to avoid immediate sending.
Click on “Schedule Broadcast” to finalize your settings. You will see a confirmation that your broadcast has been scheduled successfully. This feature allows you to manage your communications effectively without manual intervention.
Once scheduled, you can check the statistics of your broadcast through the dashboard to monitor delivery status and engagement.
Integrating WhatsApp with Pabbly Connect allows for efficient communication with multiple contacts through personalized messages. By following the outlined steps, you can set up and manage broadcasts seamlessly, enhancing your outreach efforts.
