1. Accessing Pabbly Connect for WhatsApp Broadcasts
To start using Pabbly Connect for WhatsApp broadcasts, first navigate to pabbly.com/chartflow in your browser. This will direct you to the Pabbly Chatflow homepage, where you can sign up or log in.
If you’re a new user, click on the “Sign up for free” option. For existing users, simply sign in. After logging in, you will be taken to the Pabbly apps dashboard, where you can access the various features of Pabbly Connect.
2. Setting Up Your WhatsApp Account in Pabbly Connect
Once you are in the Pabbly Chatflow dashboard, the next step is to connect your WhatsApp account. This is crucial for sending messages to your customers. Click on “Access Now” to start the process of connecting your WhatsApp number.
Follow these steps to connect your WhatsApp account:
  • Click on the WhatsApp settings option.
  • Follow the prompts to verify your WhatsApp number.
  • Ensure your account is properly set up to send messages.
After connecting your WhatsApp, you will be ready to send broadcasts through Pabbly Connect. This integration makes it easy to communicate with multiple customers at once.
