To start automating your Facebook posts, you need to access Pabbly Connect. This platform allows you to connect various applications without any coding skills. Simply go to the Pabbly Connect landing page by typing pabby.com/connect in your browser.
Once there, you will see options to sign in or sign up for free. If you are a new user, click on the “Sign up for free” button to create an account. Existing users can simply sign in. New users will receive 100 free tasks every month to explore the software.
After logging into your Pabbly Connect account, navigate to the dashboard and click on the “Create Workflow” option. Here, you can either create a workflow from scratch or use AI to generate one based on a simple prompt.
  • Select “Create from scratch” or use the AI option.
  • Provide a clear instruction, such as “Connect Facebook pages with Facebook pages”.
  • Choose the trigger event, like “New Post” on your Facebook page.
This process allows you to automate posting across multiple Facebook pages seamlessly, making social media management much easier.
3. Connecting Your Facebook Pages
Now that you’ve set up your workflow, it’s time to connect your Facebook pages using Pabbly Connect. Click on the trigger step and ensure your Facebook account is connected. If not, click on the “Add New Connection” button to link your Facebook pages.
Once connected, you will need to select the specific Facebook page that will trigger the automation. Make sure to choose the correct page where you want to capture new posts. After selecting the page, click on the “Save and Send Test Request” button to ensure everything is set up correctly.
4. Capturing Post Details for Automation
After successfully connecting your Facebook pages, you need to create a new post on your primary Facebook page. This post will serve as the trigger for the automation. Enter the image and caption for your post, and then publish it.
  • Create a new post on your primary Facebook page.
  • Publish the post to capture the response in Pabbly Connect.
  • Check the response in Pabbly Connect to ensure all details are received.
This response will include the image link, caption, and other necessary details for your automation. Use this information to set up the next steps in your workflow.
5. Posting to Multiple Facebook Pages Automatically
With the response captured, you can now set up the action to post the same content on multiple Facebook pages. Select the action step in Pabbly Connect and choose “Create Page Post” as the action.
Map the caption and image URL from the previous response to ensure each new post includes the same content. This dynamic mapping allows for automatic updates each time a new post is made on your primary page.
  • Select the action to create a new page post.
  • Map the caption and image URL from the previous response.
  • Test the automation to ensure it works correctly.
Now, whenever you post on one Facebook page, the same content will be automatically shared on the other pages, saving you time and effort.
In this tutorial, we explored how to automate your Facebook posts across multiple pages using Pabbly Connect and Pabbly Subscription Billing. By following these steps, you can streamline your social media management and ensure consistent messaging across your brand’s pages.
With Pabbly Connect, you can easily set up workflows to manage your Facebook posts without manual effort, allowing you to focus on other important aspects of your business.
