To start automating the process of saving Telegram files to Google Drive, you need to access Pabbly Connect. Open your browser and navigate to the Pabbly Connect website at pabbly.com/connect. If you are a new user, sign up for a free trial to explore its features.
Once logged in, you will be directed to the workflow page where you can create automations without any coding skills. Pabbly Connect simplifies the integration process, allowing you to connect various applications seamlessly.
2. Setting Up the Trigger with Telegram Bot
In this step, we will set up the trigger application using Pabbly Connect. Select Telegram Bot as your trigger application. Choose the event as “Watch Updates” to initiate the workflow when a new file is received in your Telegram group.
- Select “Telegram Bot” as the trigger application.
- Choose the event “Watch Updates”.
- Connect your Telegram account by entering the token received from the BotFather.
After clicking the connect button, you will need to create a new bot using the BotFather in Telegram. Once the bot is created, copy the token and paste it into Pabbly Connect to establish the connection.
3. Testing the Telegram Integration
After setting up the trigger, it’s crucial to test the integration. Send a file to your Telegram group where the bot has been added. Pabbly Connect will wait for this file to trigger the automation.
Once the file is sent, return to Pabbly Connect and check if the webhook response is received. This response should contain details about the file, including its ID and other relevant information.
- Ensure the bot has admin permissions in the group.
- Verify that the file ID is included in the webhook response.
This step confirms that Pabbly Connect is successfully receiving updates from your Telegram group, setting the stage for the next actions.
4. Filtering File Updates in Pabbly Connect
To ensure that only file updates trigger the next steps, we will use a filter in Pabbly Connect. Select the filter application and set the condition based on the file ID received from the previous step.
Configure the filter to proceed only if the file ID exists. This ensures that the workflow continues only when a file is sent, preventing unnecessary actions for other message types.
- Select the filter application in Pabbly Connect.
- Set the condition to check if the file ID exists.
This filtering process is essential for maintaining the efficiency of your automation, ensuring that only relevant updates are processed in the subsequent steps.
5. Uploading Files to Google Drive
The final step involves uploading the received files to Google Drive using Pabbly Connect. Select Google Drive as your action application and choose the event “Upload a File”.
Connect your Google account and provide the necessary permissions. Enter the file path and any other required details to complete the upload process. Utilize the file ID to ensure the correct file is uploaded to your designated Google Drive folder.
- Select Google Drive as the action application.
- Choose the event “Upload a File”.
- Map the file path and other details as required.
After completing these steps, your automation will be ready. You can now save Telegram files directly to Google Drive without any manual effort, thanks to the capabilities of Pabbly Connect.
In this tutorial, we demonstrated how to automate saving Telegram files to Google Drive using Pabbly Connect. By following these steps, you can streamline your workflow and eliminate manual file management tasks.
