To start integrating Housing.com with Google Sheets, you first need to access Pabbly Connect. Open your web browser and type in pabby.com to visit the official site.
Once on the site, click on the “Sign In” button if you are an existing user. If you are new, select “Sign Up for Free” to create a new account. You will receive 100 free tasks monthly to test the platform.
After signing in, navigate to the Pabbly Connect dashboard. Here, you can create a new workflow by clicking on the “Create from Scratch” button. Name your workflow something descriptive like “Never Miss a Property Lead Again”.
- Select the folder for your workflow.
- Click on “Create” to finalize your workflow setup.
This step sets the stage for your automation, where Pabbly Connect will handle the integration between Housing.com and Google Sheets.
3. Setting Up the Trigger with Housing.com
In your newly created workflow, the next step is to set up the trigger application. Choose Housing.com as your trigger application. The trigger event will be “New Leads”, which activates the workflow whenever a new lead is received.
Click on “Connect” to establish a connection between Pabbly Connect and Housing.com. You will be provided with a webhook URL that acts as a bridge for this integration. Note that you need to provide this URL to your Housing.com account manager for setup.
4. Capturing Lead Details from Housing.com
After setting up the webhook, click on “Capture Webhook Response”. This will change to “Waiting for Webhook Response”, indicating that Pabbly Connect is ready to receive data.
Once you receive a lead, you should see the details, including the phone number, name, and email address. This confirms that the connection between Housing.com and Pabbly Connect is working successfully.
5. Adding Lead Details to Google Sheets
Now that you have captured lead details, the next step is to add this information to Google Sheets. Click on “Add New Action Step” and select Google Sheets as your action application.
- Choose the action event “Add New Row”.
- Connect your Google account to grant Pabbly Connect access.
After selecting your spreadsheet, map the fields from the lead details to the corresponding columns in Google Sheets. This ensures that every new lead is automatically added without manual entry, streamlining your workflow.
By following these steps, you can successfully integrate Housing.com with Google Sheets using Pabbly Connect. This automation allows you to capture leads efficiently and manage them in your spreadsheet without manual input, enhancing your productivity.
