To integrate WhatsApp with Google Docs using Pabbly Connect, start by visiting the Pabbly Connect website. If you are new, sign up for a free account. Existing users can simply sign in to access their dashboard.
Once logged in, select the “Pabbly Connect” option. This platform is essential for automating workflows between WhatsApp and Google Docs, enabling seamless communication and data management.
2. Creating Your WhatsApp Assistant in Pabbly Connect
After accessing the dashboard, click on the “Create Assistant” button to begin setting up your WhatsApp automation. This is where Pabbly Connect plays a crucial role in managing automated responses.
- Enter a descriptive name for your assistant.
- Select the type of instructions for your assistant, choosing options like AI agent.
- Customize the assistant’s behavior and responses based on your preferences.
By setting these parameters, you ensure that your WhatsApp assistant responds accurately to user inquiries, making use of the powerful features of Pabbly Connect.
3. Configuring API Settings in Pabbly Connect
Next, you need to configure the API settings to connect your WhatsApp account with Pabbly Connect. This step is essential for enabling automated interactions. Enter your API key from the OpenAI platform, which allows Pabbly Connect to communicate effectively with WhatsApp.
Follow these steps to configure your API:
- Click on “API Settings” in the dashboard.
- Paste your OpenAI API key in the designated field.
- Save the settings to ensure the API is properly linked.
This configuration allows Pabbly Connect to manage automated responses on WhatsApp based on user inputs and data from Google Docs.
4. Designing Your Knowledge Base for Effective Responses
Creating a knowledge base is crucial for providing accurate and relevant responses to users. In this step, you will upload a PDF file containing the necessary information for your WhatsApp assistant. This will enhance the effectiveness of Pabbly Connect in responding to queries.
Here’s how to set up your knowledge base:
- Prepare a PDF file with all relevant business information.
- Ensure the file size is less than 90 MB and includes no more than 10 pages of images.
- Upload the PDF file in the knowledge base section of Pabbly Connect.
With this knowledge base, your WhatsApp assistant will be equipped to handle inquiries efficiently, utilizing Pabbly Connect for seamless integration.
5. Finalizing Assistant Settings and Activation
After setting up the knowledge base, it’s time to finalize your assistant’s settings. This includes customizing the interface and activating the assistant for use. The final adjustments ensure that your assistant is ready to interact with users via WhatsApp, powered by Pabbly Connect.
To finalize your settings, follow these steps:
- Customize the appearance of your assistant by setting headings and subheadings.
- Enable the assistant by toggling the activation switch.
- Click the “Save Assistant” button to complete the setup.
Once activated, your WhatsApp assistant will be fully operational, providing instant responses to user queries, thanks to the automation capabilities of Pabbly Connect.
In this tutorial, we explored how to integrate WhatsApp with Google Docs using Pabbly Connect. By following these steps, you can automate responses effectively, enhancing your business communication.
