To start tracking website sign-ups, you first need to access Pabbly Connect. This powerful tool allows you to automate processes seamlessly. If you don’t have an account, visit Pabbly’s website to sign up and receive 100 free tasks each month.
Once you log in, you will land on the Pabbly Connect dashboard. Here, you can create and manage your automation workflows. Click on the ‘Create Workflow’ button to begin setting up your integration.
In this section, we will create a workflow to track sign-ups on your website. Start by clicking the ‘+ Create Workflow’ button on your dashboard. You will see options for creating from scratch, using AI, or a quick builder. For this tutorial, select ‘Create from Scratch’.
  • Enter a name for your workflow, such as “Never Miss a Lead: Auto-Track Website Sign-Ups”.
  • Select the folder for your workflow, ideally named for easy identification.
  • Click the ‘Create’ button to finalize your workflow setup.
Once your workflow is created, the next step is to set a trigger. This is crucial as it defines when the automation will start. Choose your trigger application as “Webhook by Pabbly” to capture sign-up data from your website.
After selecting “Webhook by Pabbly” as your trigger application, click on the ‘Connect’ button. You will receive a unique webhook URL. Copy this URL, as it will be used to connect your website’s sign-up form.
Next, go to your website’s code and find the sign-up form. Paste the copied webhook URL in the appropriate field to ensure data is sent to Pabbly Connect when a user signs up. Save the changes and test the form by creating a new account to see if the data is captured correctly.
  • Fill out the sign-up form with user details.
  • Submit the form to trigger the webhook.
  • Check Pabbly Connect to confirm the data has been received.
Once confirmed, you can proceed to store this information in Google Sheets using another action in Pabbly Connect.
4. Storing Sign-Up Data in Google Sheets
Next, set up Google Sheets as your action application in Pabbly Connect. Select “Add New Row” as the action event and click ‘Connect’. If you have an existing connection, you can use it; otherwise, create a new connection by signing in with your Google account.
After connecting, choose the appropriate spreadsheet where you want to store the sign-up data. Map the fields from the webhook response to the columns in your Google Sheet. This mapping ensures that user data is accurately recorded in real-time.
  • Select the correct spreadsheet and sheet name.
  • Map fields such as first name, last name, email, and company name.
  • Click on ‘Save and Send Test Request’ to verify the setup.
Once the setup is confirmed, your workflow will automatically log new sign-ups into Google Sheets without manual entry.
5. Setting Up WhatsApp Reminders with Pabbly Connect
To enhance your lead follow-up process, you can set up WhatsApp reminders using Pabbly Connect. First, add a delay step to your workflow by selecting “Delay by Pabbly”. Set the delay time to 6 hours, which is the time frame for sending reminders.
After the delay, add another action to send a WhatsApp message using “Pabbly Chatflow”. Connect your Chatflow account by entering the required API token. This token can be found in your Pabbly Chatflow dashboard under the settings section.
  • Map the user’s phone number to send the message.
  • Craft a personalized message that includes the user’s name.
  • Click ‘Save and Send Request’ to finalize the setup.
This automated WhatsApp reminder will help keep your leads engaged and increase conversion rates.
Using Pabbly Connect, you can efficiently track website sign-ups and automatically send reminders. This integration not only saves time but also enhances customer engagement. Implement this workflow to ensure you never miss a lead again!
