1. Accessing Pabbly Connect for Your Automated Support System
To start building your automated support system, you first need to access Pabbly Connect. Visit pabbly.com and log in to your account. If you are a new user, click on “Create Free Account” to get started.
Once logged in, navigate to the Pabbly Connect dashboard. Here, you can create a new workflow by clicking on “Create Workflow”. Name your workflow appropriately, such as “Never Miss a Customer Complaint Again!” and select a folder to organize it.
2. Setting Up Google Forms with Pabbly Connect
To capture customer complaints, you will use Google Forms integrated through Pabbly Connect. Create a Google Form that includes fields for customer name, email, type of inquiry, and the inquiry itself. This form will be the starting point for your automation.
- Create a new Google Form and add necessary fields.
- Navigate to the “Responses” tab and click on “View in Sheets”.
- Copy the link to your Google Form for testing.
After setting up the form, you’ll connect it to Pabbly Connect to ensure that every new response triggers your workflow.
3. Integrating Google Sheets with Pabbly Connect
Next, you need to link Google Sheets with Pabbly Connect. This integration allows you to capture responses from Google Forms directly into your workflow. In your Pabbly Connect dashboard, select Google Sheets as the trigger app.
Choose the event “New Response Received” and connect your Google account. Once connected, select the Google Sheet that corresponds to your form. This setup will ensure that every new form submission automatically feeds into your Pabbly Connect workflow.
After configuring the trigger, test it by submitting a sample form. You should see the response reflected in Pabbly Connect, confirming that the integration is working correctly.
4. Routing Inquiries to Slack and Gmail
With your Google Forms and Sheets integrated, it’s time to route inquiries using Pabbly Connect. You can set up different channels for different types of inquiries. Create two channels in Slack: one for general inquiries and another for customer complaints.
- Add a new action step in Pabbly Connect to send messages to Slack.
- Select the appropriate Slack channel based on the inquiry type.
- Use Gmail to send email notifications for pricing inquiries.
By setting these actions, you can ensure that all inquiries are directed to the right team, enhancing your customer support process.
5. Testing and Optimizing Your Workflow with Pabbly Connect
After setting up the routing, it’s crucial to test your entire workflow in Pabbly Connect. Submit a few test inquiries through your Google Form and check if they appear in the correct Slack channels and if email notifications are sent out as expected.
If everything works as intended, consider optimizing your workflow by adding more actions or refining the existing ones. You can also adjust notification settings to suit your team’s preferences.
By continually testing and optimizing your workflow, you ensure that your automated support system remains efficient and effective, helping you never miss a customer complaint again.
This tutorial showed you how to build an automated support system using Pabbly Connect to integrate Google Forms, Gmail, and Slack. By following these steps, you can streamline customer inquiries and ensure prompt responses.
