1. Accessing Pabbly Connect for Meta Lead Ads Automation
To start automating Meta Lead Ads, you need to access Pabbly Connect. Open your browser and navigate to pabbl.com/connect. Once there, you can sign up for a free trial, allowing you to explore the features available.
After signing up, you will be directed to the workflow builder. This is where the magic happens. In this section, you will set up the integration between Meta Lead Ads and other applications like Google Sheets and HubSpot CRM using Pabbly Connect.
Once in the workflow builder, click the “Add Trigger” button. For the trigger application, select “Facebook Lead Ads” and choose the event as “New Lead Instant.” Click on “Connect” to establish this connection using Pabbly Connect.
- Ensure your Facebook account is logged in before proceeding.
- Select your Facebook page and the specific lead form for automation.
- Click “Save and Send Test Request” to capture the webhook response.
After you click “Save and Send Test Request,” it will show a message saying it is waiting for a webhook response. This is crucial for the next steps where Pabbly Connect captures the lead details for processing.
3. Testing Meta Lead Ads with Pabbly Connect
To test your lead ads, open a new tab and search for “Meta for Developers” to access the lead ads testing tool. Select your page and the product as “Lead Retrieval” to preview the form.
Fill in the required details such as name, email, and phone number. Once you submit this form, Pabbly Connect will capture these details instantly, allowing you to verify that the integration works correctly.
- Enter a sample name like “New User”.
- Provide a test email and phone number.
- Submit the form to trigger the automation.
After submitting, return to Pabbly Connect and see the captured lead details in the workflow. This confirms that the integration is functioning as expected.
4. Adding Lead Details to Google Sheets via Pabbly Connect
Now that the lead details are captured, it’s time to add them to Google Sheets. Click on “Add New Action Step” and select “Google Sheets” for the event. Choose “Add New Row” and click on “Connect” to link your Google account.
Sign in with the Gmail account you want to use and grant permissions. Once connected, select the spreadsheet and sheet where you want to add the lead details. Use the mapping feature in Pabbly Connect to dynamically insert lead data into the correct fields.
- Map fields like Name, Email, and Phone Number from the previous step.
- Click “Save and Send Request” to add the lead to your Google Sheets.
- Check your Google Sheets to confirm the details were added successfully.
This step ensures that all leads are organized in your Google Sheets, making it easy to track and manage them using Pabbly Connect.
5. Integrating Lead Details into HubSpot CRM
Next, you will integrate the captured lead details into HubSpot CRM. Click on “Add New Action Step” and select “HubSpot” for the event. Choose “Create Contact” and connect your HubSpot account through Pabbly Connect.
Once connected, map the lead details to the corresponding fields in HubSpot. Fill in the required information like Name, Email, and Phone Number. After mapping, click on “Save and Send Test Request” to create the new contact in HubSpot.
- Ensure all required fields in HubSpot are filled accurately.
- Refresh your HubSpot CRM to see the new contact added.
- Verify that the details match what was submitted.
This integration allows you to manage leads efficiently, ensuring that all data is synced seamlessly through Pabbly Connect.
In this tutorial, we demonstrated how to automate Meta Lead Ads using Pabbly Connect in just 5 minutes. By integrating Google Sheets and HubSpot CRM, you can streamline lead management effectively. Try this automation to enhance your lead nurturing process.
