To begin integrating Meta Ads and WhatsApp, you first need to access Pabbly Connect. Open your browser and navigate to pabbly.com/connect. This platform serves as the central hub for all your integration needs, enabling seamless communication between various applications.
If you are a new user, you will need to sign up for a free trial. Existing users can simply log in. Once logged in, you can start creating workflows that connect Meta Ads and WhatsApp, enhancing your lead management process.
After logging into Pabbly Connect, navigate to the workflow page where you can create your automation. Click on the option to create a new workflow. Here, you will be prompted to select your trigger application.
- Select “Facebook Lead Ads” as your trigger application.
- Choose the event as “New Lead Instant”.
- Click on the “Connect” button to build the connection.
By selecting the appropriate options, you set the stage for the integration. Ensure you have the necessary permissions to allow Pabbly Connect to access your Facebook account.
To connect Facebook Lead Ads, you need to authorize Pabbly Connect to access your Facebook account. Click on the “Connect with Facebook Lead Ads” button and select your Facebook account. After authorization, you will be able to choose the specific page and lead form from which you want to capture leads.
For instance, select your page named “The Magic Makers” and the lead form titled “New Leads”. After selecting the form, click on “Save and Send Test Request”. This action will prepare Pabbly Connect to receive data from your Facebook Lead Ads.
4. Sending WhatsApp Messages via Pabbly Connect
Once you have set up the trigger, it’s time to send WhatsApp messages automatically. For this, you will use Pabbly Chatflow, another product by Pabbly. In the action application section, select Pabbly Chatflow and choose the event as “Send Text Message”.
- Enter your API token from the Pabbly Chatflow settings.
- Map the recipient’s WhatsApp number using the data from the Facebook lead.
- Compose your message, including personalized elements like the lead’s name.
After filling in these details, click on “Save and Send Test Request”. This will trigger the WhatsApp message to be sent to the lead who filled out your Meta Ads form, showcasing the power of Pabbly Connect in automating your communication.
5. Conclusion
In this tutorial, we explored how to integrate Meta Ads and WhatsApp using Pabbly Connect. By following these steps, you can streamline your lead management and ensure instant communication with your leads. Start using Pabbly Connect today to enhance your automation capabilities.
