To begin automating your WhatsApp messages, access Pabbly Connect by visiting pabby.com/connect in your browser. This platform is essential for integrating your Facebook lead ads with WhatsApp messaging through Pabbly Chatflow.
If you are a new user, click on “Sign Up for Free” to get started with 100 free tasks each month. Existing users can simply sign in. After logging in, you will find all Pabbly applications, including Pabbly Connect, ready for use.
Once you are in Pabbly Connect, create a workflow to automate your messaging. Click on “Access Now” for Pabbly Connect and then choose to create a workflow using the Quick Builder method. This step is crucial for setting up the automation process.
  • Select “Create New Workflow” from the dashboard.
  • Name your workflow to identify it easily.
  • Choose the trigger app as Facebook Lead Ads.
After setting up the trigger, you will need to specify the action to take when a new lead is captured. This is where Pabbly Chatflow comes into play, allowing you to send personalized messages via WhatsApp.
3. Setting Up Trigger and Action
In this step, you will configure the trigger for your workflow. Select Facebook Lead Ads as your trigger app and connect your Facebook account to Pabbly Connect. You will be prompted to select the Facebook page and lead form you want to use.
After connecting, set the response format to simple for better organization. Click on “Save and Send Test Request” to ensure everything is working correctly. This step will capture a sample lead from your ads, allowing you to test the integration.
  • Ensure you have a lead form ready in your Facebook Ads Manager.
  • Use the lead testing tool to generate a test lead.
  • Verify that the lead data is captured in Pabbly Connect.
Once the lead is captured, you can proceed to set up the action step, which will send a WhatsApp message through Pabbly Chatflow.
4. Sending WhatsApp Messages via Pabbly Chatflow
To send WhatsApp messages, you need to create a connection with Pabbly Chatflow. Enter the API token from your Pabbly Chatflow account into Pabbly Connect. This connection allows you to send personalized messages directly to your leads.
Map the phone number from the lead data captured in the previous step. Then, customize your WhatsApp message to include the lead’s name for personalization. This step enhances engagement and improves your chances of converting leads into clients.
  • Enter the WhatsApp mobile number using dynamic mapping.
  • Craft a personalized message to send to each lead.
  • Test the message by sending it to your WhatsApp account.
After completing these steps, click on “Save and Send Test Request”. If successful, you will receive a confirmation message on WhatsApp, indicating that the setup is complete.
5. Conclusion
In this tutorial, we covered how to automate WhatsApp messages to your leads using Pabbly Connect and Pabbly Chatflow. We detailed the steps to access Pabbly Connect, create a workflow, set up triggers and actions, and send personalized messages.
By following these steps, you can efficiently engage with your leads and enhance your business communication. Automating your follow-up process saves time and improves lead conversion, making it an essential strategy for any business.
With Pabbly Connect, you can streamline your business processes effectively. Start automating today!
