To begin integrating Meta Ads leads with Zo CRM, you first need to access Pabbly Connect. Start by visiting the Pabbly Connect website and signing up for a free account. If you are an existing user, simply log in to your account.
Once logged in, you will be directed to the Pabbly Connect dashboard. Here, you can create a new workflow by clicking on the “Create Workflow” button. This is where you will set up the integration process for capturing leads from Meta Ads into Zo CRM.
In this section, you will create a workflow to automate the lead capturing process. Click on “Create Workflow” and give it a name related to Meta Ads leads. Select the option “Create from Scratch” to start building your workflow.
  • Select Facebook Lead Ads as the trigger application.
  • Choose “New Lead” as the event.
  • Click on “Connect” to establish a connection with your Facebook account.
After connecting, you will need to select your Facebook page and the lead generation form. Ensure that the form is correctly set to capture the necessary lead details. This setup is crucial for the automation to work effectively.
3. Generating Test Leads for Verification
Now that you have set up the workflow, it’s time to generate a test lead to verify that everything is working correctly. Use the Lead Ads Testing Tool provided by Meta to create a test lead. Fill in the required fields like first name, last name, email, and phone number.
  • Input details such as “Test” for the first name.
  • Use “[email protected]” for the email address.
  • Submit the form to generate the lead.
After submitting the form, check your Zo CRM account to see if the new contact has been created automatically. This step confirms that your Pabbly Connect integration is functioning as intended.
4. Setting Up Zo CRM Integration in Pabbly Connect
Next, you need to configure the Zo CRM integration within Pabbly Connect. Select Zo CRM as the action application in your workflow. Choose the action event “Create Contact” to add new leads into your CRM.
When prompted, you will need to connect your Zo CRM account by providing the domain URL. For Zo CRM, this is typically “zoho.in”. Once connected, you will be able to map the lead details from the previous step into the fields required by Zo CRM.
5. Verifying Integration Success
After mapping the required fields like first name, last name, and email, click on “Save and Send Test Request”. This action will send the mapped data to Zo CRM, creating a new contact based on the test lead you generated earlier.
To verify the integration’s success, log into your Zo CRM account and check for the newly created contact. You should see the details you entered in the test lead reflected in the CRM. This confirms that your Pabbly Connect automation is working perfectly, allowing seamless lead management from Meta Ads to Zo CRM.
The integration of Meta Ads leads into Zo CRM using Pabbly Connect simplifies your lead management process. By following these steps, you can automate the addition of new leads, ensuring that your CRM is always up to date with the latest information.
