To begin integrating J Style with Google Sheets, the first step is to access Pabbly Connect. Visit the Pabbly website by typing pabby.com in your browser. Once there, you can either sign in or sign up for a free account.
If you are a new user, click on “Sign up for free” to receive 100 free tasks monthly. Existing users can simply click “Sign in” at the top right corner. After signing in, you’ll be directed to the Pabbly apps page, where you can select Pabbly Connect.
After accessing Pabbly Connect, you can create a new workflow. Start by clicking the plus icon to create a new folder or directly create a workflow. Name your workflow appropriately and select a folder for organization.
  • Name your workflow to reflect its purpose.
  • Select the folder to keep your automations organized.
  • Click “Create” to finalize the workflow setup.
Once created, a box will appear for entering your trigger application. This is where you will set up the automation to capture new leads from J Style directly into Google Sheets using Pabbly Connect.
3. Setting Up the Trigger with J Style
In the trigger application section of Pabbly Connect, select J Style as your trigger application. Choose the trigger event as “New Leads” to activate the workflow whenever a new lead is captured.
To connect J Style with Pabbly Connect, a webhook URL will be generated. This URL acts as a bridge between J Style and Pabbly. Since J Style does not allow users to add this URL directly, you must send it to your account manager at J Style to set it up. After the setup, click on “Capture Webhook Response” to confirm the connection.
4. Adding Action to Google Sheets
After successfully capturing the webhook response, the next step is to add the action to Google Sheets. In Pabbly Connect, select Google Sheets as your action application and choose “Add New Row” as the action event.
  • If no existing connection exists, click “Add New Connection”.
  • Sign in with your Google account to grant permissions.
  • Select the specific spreadsheet you want to use.
Once connected, map the fields from J Style to the corresponding fields in your Google Sheets. This ensures that every new lead is automatically recorded in your spreadsheet, streamlining your data management process with Pabbly Connect.
5. Testing the Integration
With everything set up, it’s time to test your integration between J Style and Google Sheets using Pabbly Connect. Click “Save and Send Test Request” to verify that the data flows correctly from J Style into Google Sheets.
Check your Google Sheets to confirm that the lead details appear as expected. If everything is set up properly, you should see the new lead information reflected in your spreadsheet. This confirms that your automation workflow is functioning correctly, thanks to Pabbly Connect.
In this tutorial, we detailed how to integrate J Style with Google Sheets using Pabbly Connect. By following these steps, you can automate lead capture and streamline your data management effectively. This integration enhances efficiency and saves time, allowing you to focus on growing your business.
