To start automating LinkedIn posts, first access Pabbly Connect by typing “Pabbly.com/connect” in your browser. This powerful platform allows you to connect multiple applications seamlessly.
If you are a new user, click on the “Sign Up for Free” button. This grants you access to 100 free tasks each month for creating your automations. Existing users should click on the “Sign In” button to access their accounts.
Once logged into Pabbly Connect, navigate to the “Create Workflow” button. This is where you can start building your automation workflow to post on LinkedIn automatically.
- Click on “Create Workflow” to begin.
- Select the trigger application, in this case, Google AI Studio.
- Set the desired schedule for your posts.
After creating the workflow, you can set the schedule to generate content daily. This allows Pabbly Connect to automate the posting process without any manual effort.
3. Connecting Google AI Studio and LinkedIn
To generate content, you need to connect Google AI Studio with Pabbly Connect. Start by clicking on the “Add to Connection” button in your workflow.
Follow these steps to connect:
- Generate an API key from Google AI Studio.
- Copy the API key and paste it into the Pabbly Connect interface.
- Connect your Google AI account by clicking “Connect with Google AI”.
Once connected, you can configure the prompts to instruct Google AI on the content you want for your LinkedIn posts. This is how Pabbly Connect facilitates the integration between these applications.
4. Posting Generated Content to LinkedIn
After generating content with Google AI Studio, the next step is to post it to your LinkedIn account through Pabbly Connect. Click on the “Add to Connection” button again, but this time for LinkedIn.
Follow these steps:
- Sign in to your LinkedIn account through Pabbly Connect.
- Use mapping to add the generated content from Google AI Studio.
- Click “Save and Send Test Request” to post the content.
With this setup, Pabbly Connect will automatically post new content to your LinkedIn account daily, ensuring you have fresh posts without manual input.
5. Conclusion
Using Pabbly Connect to automate LinkedIn posts is a straightforward process. By following the steps outlined above, you can effortlessly integrate Google AI Studio to generate and post content daily on LinkedIn.
This automation not only saves time but also ensures consistent engagement on your LinkedIn profile.
