To start automating Facebook video posts, access Pabbly Connect by visiting pabbly.com/connect. This platform will help you integrate various applications seamlessly.
If you’re a first-time user, sign up for free to receive 100 tasks every month. Once logged in, you can begin creating your automation setup. Pabbly Connect’s user-friendly interface makes it easy to set up integrations without any coding skills.
2. Setting Up Google Sheets with Pabbly Connect
The next step involves connecting Google Sheets to Pabbly Connect. This integration allows you to input video prompts and styles directly into a spreadsheet.
Follow these steps to set it up:
  • Open your Google Sheets and go to Extensions.
  • Select Add-ons and search for Pabbly Connect Webhooks to install.
  • After installation, refresh the spreadsheet to see Pabbly Connect options.
Now, you can paste the webhook URL provided by Pabbly Connect into the setup dialog to link your spreadsheet with the automation.
3. Creating Video Content with Gemini AI
Once your Google Sheets is set up, you can use Pabbly Connect to generate video content through Gemini AI. This requires mapping the data from your spreadsheet to create engaging video captions.
To generate video content:
  • Select the Gemini AI integration in Pabbly Connect.
  • Add your API key to connect Gemini with Pabbly Connect.
  • Map the video idea and style from your Google Sheets into the Gemini AI prompt.
After setting this up, you can generate video content that aligns with your specified prompts, ensuring a seamless process of video creation and posting to Facebook.
4. Posting Generated Videos to Facebook
The final step is to post the generated video content from Gemini AI to your Facebook page using Pabbly Connect. This allows you to share your created videos directly as posts.
To post on Facebook:
  • Connect your Facebook account within Pabbly Connect.
  • Map the video URI and caption generated by Gemini AI to the Facebook post fields.
  • Click save and send test request to publish your video on Facebook.
After a successful test, your video will be posted on your Facebook page, completing the automation process using Pabbly Connect.
5. Conclusion
In this tutorial, we explored how to automate Facebook video posting using Pabbly Connect and Gemini AI. By following these steps, you can easily create engaging video content directly from Google Sheets and share it on Facebook.
Utilizing Pabbly Connect streamlines the entire process, allowing you to focus on your creative ideas without the need for technical skills. Start automating today to enhance your social media presence efficiently.
