To start automating Facebook posts, access Pabbly Connect by visiting the official website. Here, you can sign up for a free account or log in if you’re an existing user. A free account allows you to explore 100 tasks each month, making it ideal for testing automations.
After logging in, you will be directed to the dashboard. Here, you can create a new workflow that integrates Google Sheets with Facebook Pages. This setup will enable you to automatically post content to multiple Facebook pages based on the data entered in Google Sheets.
2. Setting Up the Trigger with Google Sheets
The first step in your automation process is to set up a trigger. In Pabbly Connect, select Google Sheets as your trigger application. Choose the event “New or Updated Spreadsheet Row” to initiate the workflow whenever a new row is added or updated.
  • Log in to your Google account and open the Google Sheet where you will enter your post details.
  • Navigate to Extensions > Add-ons > Get Add-ons, and install the Pabbly Connect Webhooks add-on.
After installing, set up the webhook in your Google Sheet. Enter the copied URL in the Pabbly Connect Webhooks settings, and specify the trigger column as the last column of your sheet. This configuration allows Pabbly Connect to fetch data automatically whenever a new entry is made.
3. Generating Content Using OpenAI
Next, integrate OpenAI to generate content for your Facebook posts. In Pabbly Connect, select OpenAI as your action application. Choose the event “Chat GPT” to create content based on the theme and description entered in Google Sheets.
To establish a connection, you will need your OpenAI API key. Follow the prompts in Pabbly Connect to enter this key. After connecting, you will set up the prompt for content generation. Use dynamic mapping to insert the title and description from Google Sheets directly into the prompt.
  • Select the AI model, such as GPT-5, for generating text.
  • Map the title and description fields from the Google Sheets response.
After setting up the prompt, click “Save and Send Test Request” to generate the content. This step showcases how Pabbly Connect seamlessly connects your Google Sheets data to OpenAI for automated content creation.
4. Posting Generated Content to Facebook
Once the content is generated, the next step is to post it to your Facebook pages. In Pabbly Connect, select Facebook Pages as your action application. Choose the event “Create Page Post” to publish the content generated by OpenAI.
Establish the connection with your Facebook account. You will need to authorize Pabbly Connect to access your Facebook pages. After connecting, select the page where you want to post the content and map the message field to the response from OpenAI. This allows the generated content to be posted directly to your Facebook page.
  • Select the target Facebook page for your post.
  • Map the content generated by OpenAI to the message field.
After mapping, click “Save and Send Test Request” to publish the post. Refresh your Facebook page to verify that the post appears as intended. This demonstrates the power of Pabbly Connect in automating social media management.
5. Conclusion
By following these steps, you can successfully automate Facebook posts using Pabbly Connect, Google Sheets, and OpenAI. This integration not only saves time but also enhances your social media strategy. Start using Pabbly Connect today to streamline your automation processes.
