To start the integration process, access Pabbly Connect by visiting pabbly.com/chatflow in your browser. This platform allows you to efficiently manage your WhatsApp broadcasts.
If you are a new user, you can sign up for free. Existing users can simply log in. Once logged in, navigate to the Pabbly Chatbot dashboard where you can manage your WhatsApp account.
2. Creating a Template Message in Pabbly Connect
Before sending broadcasts, you need a pre-approved template message in Pabbly Connect. This template will be used for your WhatsApp broadcast.
  • Navigate to the template section within Pabbly Chatbot.
  • Create your message, ensuring it adheres to WhatsApp’s guidelines.
  • Submit the template for approval by Meta.
Once approved, you can use this template for your broadcasts. Ensure that your message is engaging and includes any necessary images or media for better outreach.
3. Setting Up Your WhatsApp Broadcast with Pabbly Connect
To send out your promotional message, navigate to the broadcast section in Pabbly Connect. Here, you can create a new broadcast campaign.
Click on the “Add Broadcast” button, and select the type as “Broadcast Campaign”. Name your campaign, for example, “New Launch Offer”. Next, you will be prompted to select a contact list.
  • Upload your contacts via CSV or select from existing lists.
  • You can refine your audience by excluding specific contacts if necessary.
  • Choose the message type as either a pre-approved template or a regular message.
After configuring your audience and message type, you can proceed to test your broadcast to ensure everything is set up correctly.
4. Testing and Scheduling Your Broadcast in Pabbly Connect
Before sending out your WhatsApp broadcast, it’s crucial to test it using Pabbly Connect. Send a test message to your own WhatsApp number to verify the content.
Once confirmed, you can schedule your broadcast. Select whether you want to send it immediately or schedule it for a later date and time. Ensure you choose a future date to avoid sending messages instantly.
  • Turn on automatic retries for failed contacts if needed.
  • Click on “Add Broadcast” to finalize the setup.
After scheduling, you can view broadcast stats, including sent, delivered, and read messages. This feature allows you to track the effectiveness of your campaign.
5. Conclusion: Efficient WhatsApp Broadcasts with Pabbly Connect
Using Pabbly Connect for WhatsApp broadcasts streamlines the process of reaching your customers effectively. By following the steps outlined, you can set up your campaigns with ease.
In summary, Pabbly Connect not only simplifies the integration of WhatsApp but also enhances your marketing efforts through efficient automation. Start using Pabbly Connect today to elevate your business communications!
