To start using Pabbly Chatflow, open your browser and navigate to pav.com/chatflow. This is where you can sign up or log in to your account. If you are a new user, click on “Sign Up for Free” to create an account. Existing users can simply sign in.
Once logged in, you will see all Pabbly applications. Click on “Access Now” under Pabbly Chatflow to reach the dashboard. Here, you can manage your WhatsApp communications effectively. If you need to connect a WhatsApp number, follow the tutorial available on the Pabbly YouTube channel.
2. Setting Up WhatsApp Broadcast in Pabbly Chatflow
In this section, we will set up a WhatsApp broadcast using Pabbly Chatflow. First, navigate to the broadcast section in the left sidebar. Here, you can see existing broadcasts and their statuses. To create a new broadcast, click on the “Add Broadcast” button.
  • Select “Broadcast Campaign” from the drop-down menu.
  • Name your broadcast, e.g., “New Weekend Offer”.
  • Choose your audience from an existing contact list or upload a CSV file.
After naming your broadcast, refine your audience by excluding contacts you do not wish to message. This feature allows you to target your messages more effectively, ensuring that only relevant customers receive your offers.
3. Creating a Message Template in Pabbly Chatflow
Before sending out your broadcast, you need a message template. In Pabbly Chatflow, go to the template section. Here, you can create a new message template or use an existing one. Ensure that your template is approved by Meta for it to be used in broadcasts.
Once your template is ready, you can personalize it using variables. For example, include a variable for the customer’s name to make the message feel more personal. This enhances customer engagement and response rates.
4. Testing and Scheduling Your WhatsApp Broadcast
After setting up your broadcast and message template in Pabbly Chatflow, it’s time to test the message. Enter your own contact details and click on “Send Test Message”. This allows you to verify that the message appears as intended before sending it to your entire contact list.
Once the test is successful, you can schedule the broadcast. Choose whether to send the message immediately or at a later date. If scheduling, ensure you select a future date and time to avoid sending messages prematurely.
5. Monitoring Broadcast Results in Pabbly Chatflow
After your broadcast is sent, you can monitor its performance using Pabbly Chatflow. The dashboard provides insights into sent, delivered, and read messages. This data helps you analyze the effectiveness of your campaigns and make necessary adjustments for future broadcasts.
If there are any failed messages, you can resend them easily. Simply select the resend option next to the broadcast entry to ensure all contacts receive your offers.
In this tutorial, we explored how to use Pabbly Chatflow to send WhatsApp broadcasts efficiently. By following these steps, you can automate your messaging process and enhance customer engagement with personalized offers.
