1. Accessing Pabbly Connect for WhatsApp Campaigns
To launch a profitable WhatsApp campaign, start by accessing Pabbly Connect. Open your browser and navigate to the Pabbly Connect website to create your account.
Once your account is set up, log in to access the dashboard. Here, you can integrate various applications like Pabbly Chat Flow and CSV files to streamline your WhatsApp marketing efforts.
2. Setting Up Pabbly Chat Flow
Next, you need to set up Pabbly Chat Flow. After logging in, ensure your WhatsApp number is added to your account. This is crucial for sending messages through the platform.
From the left menu, select the option for “Broadcast” to initiate your campaign. Before proceeding, create a message template you wish to send to your customers. This template will be the basis for your broadcast.
  • Navigate to the “Templates” section.
  • Click on “Add Template” to create your message.
Now that your template is ready, you can move on to creating your contact list for the broadcast.
3. Creating Your Contact List in Pabbly Connect
In this step, you will create a contact list within Pabbly Connect. Select the “Contacts” option from the left menu and click on “Add New Contact List” to start building your audience.
With your contact list ready, you can now set up the broadcast campaign. Choose the broadcast type as a campaign and name it accordingly, such as “Profitable Campaign”.
  • Select the audience for your broadcast.
  • You can upload a CSV file or select the contact list you created.
After selecting your audience, proceed to refine your audience if needed, but this step is optional.
4. Sending Messages Through Pabbly Connect
Now you’re ready to send messages via Pabbly Connect. Choose the type of message you want to send. You can select a regular message or a template message that has been verified by Meta.
For immediate sending, you can input your message directly. If using a template, select the template you created earlier and add any images or additional content as necessary. You can also send a test message to ensure everything looks correct.
  • Choose the option to send a test message.
  • Verify the message in your WhatsApp application.
Once verified, you can proceed to schedule your broadcast or send it immediately.
5. Scheduling and Tracking Your Campaign
In the final step, you can choose to schedule your broadcast using Pabbly Connect. If you want to send the message immediately, select the option for instant sending. Alternatively, you can choose to schedule it for a later date and time.
After scheduling, you have the option to enable automatic retries for contacts that did not receive the message successfully. This ensures that your campaign reaches as many customers as possible.
  • Set the date and time for your scheduled broadcast.
  • Activate automatic retries for failed messages.
Once your campaign is live, you can track its performance by selecting the “View Statistics” option to see delivery rates and engagement metrics.
By following these steps, you can successfully launch a profitable WhatsApp campaign in just 5 minutes using Pabbly Connect. This integration with Pabbly Chat Flow and CSV makes it easy to reach your customers effectively.
