To create a WhatsApp chatbot, you’ll first need to access Pabbly Connect. Open your browser and navigate to the Pabbly website. If you are a new user, sign up for a free trial to explore the features.
Once logged in, you can start creating your WhatsApp chatbot. This integration allows you to automate lead collection and notifications seamlessly. Ensure you have your WhatsApp number ready for the setup.
2. Setting Up Your WhatsApp Chatbot with Pabbly Connect
In the Pabbly Connect dashboard, select the option to create a new flow. Here, you will set up a trigger for your WhatsApp chatbot. You can choose a keyword or regex match to initiate the chatbot.
- Select a trigger event to start your chatbot.
- Set up the welcome message that users will receive.
- Add buttons for services offered by your business.
These steps allow you to create an engaging chatbot experience for your users. Once the setup is complete, you can test the chatbot to ensure it responds correctly to user inputs.
3. Collecting User Data with Pabbly Connect
After the initial interaction, your chatbot will need to collect user data. Using Pabbly Connect, you can set up actions to ask users for their full name, business name, and email address.
Utilize the ask question node to guide users through the data collection process. Once the user provides their details, the data will be stored in a contact custom field for future reference.
- Create a question node for the user’s full name.
- Add custom fields for storing collected data.
- Ensure all collected data is saved properly in the system.
This structured approach to data collection not only enhances user experience but also ensures that you have all necessary information saved for follow-ups.
4. Integrating Google Sheets and Slack via Pabbly Connect
Once the user data is collected, you can integrate Google Sheets and Slack using Pabbly Connect. This integration allows you to automatically save user data to a Google Sheet and notify your team on Slack.
To set this up, create an API request node in your flow. Here, you will enter the webhook URL provided by Pabbly Connect. This connection will facilitate data transfer between your WhatsApp chatbot and the applications.
- Enter the webhook URL in the API request node.
- Select Google Sheets as the destination for data storage.
- Set up Slack notifications for new leads.
This integration ensures that your team is promptly informed about new leads, allowing for timely follow-up and engagement.
5. Finalizing Your WhatsApp Chatbot with Pabbly Connect
After setting up the integrations, finalize your WhatsApp chatbot by adding a confirmation message for users. This message can include a prompt for any questions they may have.
Utilizing the AI Assistant feature within Pabbly Connect, you can automate responses to user queries. This ensures that users receive prompt assistance based on your business details.
- Add a confirmation message to conclude the chatbot interaction.
- Implement the AI Assistant for automated responses.
- Test the entire flow to ensure smooth operation.
With these final adjustments, your WhatsApp chatbot will be fully functional, automating lead collection and providing valuable responses to user inquiries.
In this tutorial, we explored how to create a WhatsApp chatbot using Pabbly Connect, integrating it with Google Sheets and Slack. This automation streamlines lead collection and enhances customer interaction, making your business processes more efficient.
