To start integrating LinkedIn with WhatsApp, you need to access Pabbly Connect. Begin by visiting the Pabbly website by typing pabbly.com in your browser.
Once on the site, sign in to your account. If you are a new user, you can sign up for free to explore the features. After signing in, navigate to the Pabbly Connect dashboard where all your workflows can be managed.
Next, you will create a new workflow in Pabbly Connect. Click on the “Create Workflow” button to start. Name your workflow something descriptive, like “Interact with LinkedIn Leads in Minutes”.
  • Choose a folder for your workflow, such as “LinkedIn Automations”.
  • Click on “Create” to finalize your new workflow.
Your workflow is now created successfully. This will serve as the foundation for automating your LinkedIn lead interactions through WhatsApp.
3. Setting Up the Trigger for LinkedIn Leads
The next step involves setting up a trigger in your Pabbly Connect workflow. A trigger is an event that initiates the workflow. For this integration, select LinkedIn as your trigger application.
Choose the event as “Lead Notification” and click on “Connect”. If you don’t have an existing connection, create a new one by entering your LinkedIn credentials. Once connected, save and send a test request to ensure the connection is active.
4. Capturing Lead Information from LinkedIn
After setting the trigger, it’s time to capture lead information in Pabbly Connect. Perform a test submission using your LinkedIn lead generation form to generate a lead.
  • Fill out the form with necessary details like name, email, and phone number.
  • Submit the form to send the data to your Pabbly Connect workflow.
Once the form is submitted, return to Pabbly Connect to verify that the lead details have been captured successfully. This confirms that your trigger is functioning correctly.
5. Sending WhatsApp Messages via Pabbly Chatflow
The final step is to set up an action in Pabbly Connect to send a WhatsApp message. Click on “Add New Action Step” and select Pabbly Chatflow as your action application.
Choose the action event as “Send Text Message”. Connect to your Pabbly Chatflow account by entering the necessary API token. Once connected, map the lead’s details to personalize the message. For example, you can include the lead’s name in the message.
After setting up the message, click on “Save and Send Test Request” to check if the WhatsApp message is sent successfully. You should receive a confirmation message on WhatsApp, indicating that the integration is working as intended.
In this tutorial, we explored how to integrate LinkedIn with WhatsApp using Pabbly Connect. Automating your lead interactions can save time and enhance communication with potential clients.
