1. Setting Up Pabbly Connect for Your WhatsApp Chatbot
To create an automated WhatsApp chatbot, you need to start by accessing Pabbly Connect. This platform allows you to integrate various applications seamlessly. Begin by visiting the Pabbly Connect website and signing up or logging into your account.
Once logged in, navigate to the dashboard where you can create a new workflow. Click on “Create Workflow” and give it a descriptive name, like “WhatsApp Chatbot Integration.” This is where you will set up the automation that connects your WhatsApp chatbot with other applications.
2. Configuring WhatsApp with Pabbly Connect
Next, you need to configure your WhatsApp number within Pabbly Connect. This step is crucial as it enables the chatbot to send and receive messages through WhatsApp. To do this, go to the settings page and enter your WhatsApp number.
  • Navigate to the settings section of Pabbly Connect.
  • Input your WhatsApp number in the designated field.
  • Verify your number to ensure it’s connected properly.
After entering your WhatsApp number, save the settings. This allows Pabbly Connect to use this number for all automated responses and interactions with your customers.
3. Creating the Chatbot Flow in Pabbly Connect
Now that your WhatsApp is set up, it’s time to create the chatbot flow. In Pabbly Connect, you will design how the chatbot interacts with users. Start by selecting the “Flow” option and then “Create New Flow.” Give it a name that reflects its purpose, like “Instant Reply Chatbot.”
Within the flow setup, you will need to define triggers and responses. For example, you can set a keyword trigger like “hello” to initiate the chatbot conversation. This means when a user sends “hello,” the chatbot will respond with a welcome message and options for further interaction.
4. Adding Travel Packages to Your Chatbot
To provide users with options, you can add travel packages to the chatbot. This is where Pabbly Connect shines, allowing you to create interactive buttons. For instance, after the welcome message, you can create a button labeled “Travel Packages” that users can click to view available options.
  • Create a message node for the welcome message.
  • Add a button for “Travel Packages” in the message node.
  • Set up a list of packages that users can choose from.
Once users select a package, the chatbot can then ask for additional details like travel dates and names, making the booking process smooth and efficient through Pabbly Connect.
5. Finalizing Your WhatsApp Chatbot
After setting up the travel packages, it’s essential to finalize your chatbot. This involves testing the flow to ensure everything works as intended. Use Pabbly Connect to simulate user interactions and make adjustments as necessary.
Once you are satisfied with the setup, save your flow. This ensures that your WhatsApp chatbot is ready to handle customer queries and bookings automatically. With Pabbly Connect, you can now enjoy a fully functional chatbot that enhances customer engagement without any manual effort.
In this tutorial, we explored how to create a WhatsApp chatbot for your business using Pabbly Connect. By following these steps, you can automate customer interactions and streamline your booking process effectively.
