To start integrating Instagram and Telegram, you need to access Pabbly Connect. Open a new tab and type the URL: pave.com/connect. This will take you to the Pabbly homepage.
If you’re a new user, click on “Sign Up Free” to create your account. After signing up, you will receive 100 free tasks every month to explore Pabbly Connect. If you’re an existing user, simply click “Sign In” to access your dashboard.
Once logged into Pabbly Connect, navigate to the workflow page. This is where you’ll create your automation. Click on “Create Workflow” to start.
  • Select Instagram as your trigger app.
  • Choose the event as “New Media Posted”.
  • Click the “Connect” button to link your Instagram account.
After connecting, you will be prompted to save and test the connection. This step ensures that Pabbly Connect can retrieve the necessary information from your Instagram account.
3. Setting Up Telegram Notifications Using Pabbly Connect
Next, you will set up the action app, which is Telegram. This is where Pabbly Connect sends notifications about your Instagram posts.
To do this, select Telegram as your action app and choose the event as “Send a Text Message”. You will need to connect your Telegram account by entering a token from the BotFather.
  • Search for the BotFather in Telegram.
  • Create a new bot and copy the access token provided.
  • Paste the token back into Pabbly Connect to establish the connection.
Once the connection is established, you will need to enter the chat ID of the group where notifications will be sent. This allows Pabbly Connect to communicate effectively with your Telegram group.
4. Mapping Data for Dynamic Notifications
In this step, you will map data from Instagram to Telegram. This is crucial for ensuring that the notifications sent to your Telegram channel include the correct details from your Instagram posts.
Use the mapping feature in Pabbly Connect to dynamically insert the caption and link of the Instagram post into the Telegram message. This means you won’t have to manually enter these details each time.
To map the data, select the fields from the previous Instagram step. This will ensure that every new post triggers a notification with the correct information.
5. Testing Your Integration in Pabbly Connect
Finally, test your integration to ensure everything is working correctly. After setting up your mapping, click on “Save and Send Test Request” in Pabbly Connect.
This action will simulate a new Instagram post and check if the notification is sent to your Telegram channel. If successful, you will see a confirmation message in Pabbly Connect.
Check your Telegram channel to verify that the notification has been received. This confirms that your integration is set up correctly and that Pabbly Connect is functioning as intended.
This tutorial has guided you through integrating Instagram and Telegram using Pabbly Connect. By automating notifications for your Instagram posts, you can enhance your business communication effortlessly. Start using Pabbly Connect today to streamline your social media updates!
