To start using Pabbly Connect, visit the Pabbly website by typing Pabbly.com in your browser. This platform serves as the central hub for integrating various applications, such as WooCommerce and Pabbly Chatflow.
Once on the site, you will need to sign in to your existing account or sign up for a new one. New users receive 100 free tasks monthly, allowing you to explore the features of Pabbly Connect and determine if it suits your business needs.
After signing in, navigate to the dashboard of Pabbly Connect. Here, you can create a new workflow by clicking on the “Create Workflow” button. Name your workflow something like “Increase Repeat Sales with Personalized WhatsApp Messages for WooCommerce Customers”.
- Select the folder where you want to save this workflow.
- Click on “Create” to finalize your new workflow.
This step sets the foundation for automating WhatsApp messages whenever a new order is placed in WooCommerce, utilizing the capabilities of Pabbly Connect.
3. Setting Up the Trigger for WooCommerce Orders
Next, you’ll need to establish the trigger for your workflow. In Pabbly Connect, select WooCommerce as your trigger application. The specific trigger event to choose is “New Order Created”.
Once selected, click on the “Connect” button. You will be provided with a webhook URL that acts as a bridge between your WooCommerce store and Pabbly Connect. Copy this URL and head over to your WooCommerce settings.
- Navigate to the WooCommerce settings and find the “Advanced” tab.
- Click on “Webhooks” and then “Add Webhook”.
- Fill in the details, including the webhook URL you copied from Pabbly Connect.
By saving this webhook, you enable WooCommerce to send order details directly to Pabbly Connect, triggering your automation.
4. Capturing the Webhook Response in Pabbly Connect
After setting up the webhook, return to Pabbly Connect and click on “Capture Webhook Response”. This action allows you to test the connection by creating a new order in your WooCommerce store.
Go to your WooCommerce store, select a product, and complete the checkout process. Once the order is placed, Pabbly Connect will capture the order details. You should see the order information, including the customer’s name, address, and the product ordered.
- Ensure all necessary information is captured correctly in Pabbly Connect.
- This confirms that your connection is functioning properly.
With this step completed, you are now ready to set up the action that sends WhatsApp messages using Pabbly Chatflow.
5. Sending WhatsApp Messages via Pabbly Chatflow
In the next step, select Pabbly Chatflow as your action application within Pabbly Connect. Choose the action event “Send Text Message” and click on “Connect”.
You will need to enter the connection token from your Pabbly Chatflow account. Navigate to your Pabbly Chatflow settings, find the API section, and copy the token. Paste it into Pabbly Connect to establish the connection.
- Map the customer’s phone number from the WooCommerce response.
- Craft a personalized message using the customer’s name and product details.
Once everything is set, click on “Save and Send Request”. If successful, you will receive a positive response confirming that the WhatsApp message has been sent, completing the integration process through Pabbly Connect.
In this tutorial, we explored how to integrate WooCommerce with Pabbly Connect and Pabbly Chatflow to automate personalized WhatsApp messages for new orders. By leveraging Pabbly Connect, you can enhance customer engagement and trust in your business.
