1. Accessing Pabbly Connect for WhatsApp AI Integration
To start increasing customer conversions with WhatsApp AI, you need to access Pabbly Connect. Open your browser and navigate to pabbly.com/chatflow. This will direct you to the Pabbly Chat Flow homepage.
If you’re a new user, click on the “Sign Up Free” button to create an account. Existing users can simply log in. Once logged in, find the option to access Pabbly Chat Flow and click on “Access Now” to enter the dashboard.
2. Creating Your AI Agent in Pabbly Chat Flow
After accessing Pabbly Connect, you can create an AI agent for WhatsApp. On the left sidebar, locate the “AI Assistant” feature. Here, you will see the total number of assistants you have created.
- Click the “Add” button to create a new assistant.
- Name your assistant and click “Add” again to proceed.
- You will be directed to a flow setup window.
In this setup, select the type of instruction from the dropdown. You can either use predefined examples like AI Agent or Customer Support Agent. After selecting, the basic instructions will update accordingly in the interface.
Now, it’s time to configure the AI settings within Pabbly Connect. Start by adjusting the temperature setting, which determines the creativity of the AI’s responses. A lower value, like 0.4, yields more focused answers.
Next, choose OpenAI as the AI service provider and select the GPT-5.4 model from the dropdown. You will also need to input your OpenAI API key to connect it with your AI assistant.
- Click the link provided to access your OpenAI API keys.
- Create a new secret key and label it appropriately.
- Copy the key and paste it into Pabbly Connect.
Once the API key is entered, click on the connect button to save your settings. This integration allows your AI to fetch responses from OpenAI seamlessly.
4. Setting Up Message and Keyword Responses
In this section, you will configure the message settings for your AI assistant in Pabbly Connect. You can set a header message that will be displayed to users when they initiate a chat. This message can be up to 60 characters long.
- Enable the header message option and input your desired text.
- Add keywords that will trigger human intervention when mentioned by users.
- Set a fallback message for when the AI cannot provide an answer.
For example, if a user types “human,” the assistant will stop responding, allowing a human to take over the conversation. This ensures that sensitive queries are handled appropriately.
5. Deploying Your AI Agent on WhatsApp
Once your AI agent is configured, the next step is deploying it through Pabbly Connect. Go to the settings of your inbox under the settings menu. Scroll to the Automated Reply Settings for AI.
Enable the option to allow your AI assistant to respond to chats. From the dropdown, select the contact list you want the assistant assigned to and choose the assistant you just created.
- Click on the save button to finalize your settings.
- You can also assign the assistant to individual chats by selecting a specific WhatsApp conversation.
This deployment allows your AI agent to handle customer inquiries automatically, thus increasing your customer conversions through WhatsApp AI.
In this tutorial, we explored how to use Pabbly Connect to increase customer conversions by integrating WhatsApp AI with OpenAI and Pabbly Chat Flow. By following these steps, you can create an effective AI assistant for your business.
