To get started with integrating Pabbly Connect, visit the official website. Pabbly Connect serves as the central platform that facilitates seamless connections between various applications, including Wonderly Travels and OpenAI.
Once on the Pabbly Connect homepage, you can log in or sign up for a new account. This step is crucial as it allows you to access the integration features that will automate your customer interactions.
2. Creating an AI Assistant with Pabbly Chatbot
Creating an AI assistant is straightforward with Pabbly Chatbot. Start by navigating to the Pabbly Chatbot interface where you can set up your assistant to respond to customer queries effectively.
  • Select the option to create a new AI assistant.
  • Enter your business details, specifically for Wonderly Travels.
  • Customize the initial greeting message for your users.
After setting this up, your AI assistant will be ready to handle queries from your website visitors. This integration ensures that users receive instant responses through WhatsApp using Pabbly Connect.
3. Linking OpenAI API with Pabbly Connect
To enhance your AI assistant’s capabilities, you need to integrate OpenAI API through Pabbly Connect. This process allows your assistant to provide more personalized responses based on your business’s knowledge base.
Follow these steps to link OpenAI API:
  • Access the AI instructions tab in Pabbly Chatbot.
  • Select OpenAI as the AI model and enter your API key.
  • Set the temperature for responses to control creativity.
By completing this integration, your AI assistant will utilize OpenAI’s advanced capabilities to respond accurately to customer queries related to Wonderly Travels.
4. Embedding Your AI Assistant on Your Website
Once your AI assistant is configured, the next step is embedding it on your website. Pabbly Connect simplifies this process, enabling you to integrate the assistant seamlessly.
To embed your AI assistant, follow these steps:
  • Click on the embed button in the Pabbly Chatbot interface.
  • Copy the provided script code.
  • Paste the script into the code section of your website.
After embedding, refresh your website to see the AI assistant in action. This integration allows visitors to initiate conversations directly through WhatsApp, enhancing customer engagement.
5. Conclusion
In this tutorial, we explored how to integrate Pabbly Connect with Wonderly Travels and OpenAI using Pabbly Chatbot. By following these steps, you can create a responsive AI assistant that streamlines customer interactions.
Utilizing Pabbly Connect, you can automate conversations and provide instant support to your customers, enhancing their experience significantly.
