1. Accessing Pabbly Chatflow for Your WhatsApp Chatbot
To create a WhatsApp chatbot, you first need to access Pabbly Chatflow. Open your browser and enter the URL www.pabbly.com/chatflow to reach the platform.
After navigating to the site, sign in to your existing account or sign up for a new one. If you are a new user, you will receive credits to test the features. Click on the “Sign In” button on the top right corner if you already have an account.
2. Setting Up WhatsApp Integration in Pabbly Chatflow
Once logged in, you will be directed to the Pabbly Chatflow dashboard. Here, you can add your WhatsApp number to begin the integration process. Click on the “Add WhatsApp Number” button.
  • Choose the WhatsApp Connect option for easier integration.
  • Alternatively, you can use the manual token method.
  • Follow the detailed video instructions provided for setup.
After connecting your WhatsApp, you can start creating your chatbot. This is where Pabbly Chatflow truly shines, enabling seamless communication through WhatsApp.
3. Creating Your AI Assistant in Pabbly Chatflow
To create a WhatsApp chatbot, navigate to the “AI Assistant” section within Pabbly Chatflow. Click on “Add AI Assistant” and name it, for example, “Receptionist AI”.
Once named, you’ll need to fill in the required details. Set the AI instruction type as “AI Agent” to define how your chatbot will respond. Adjust settings like temperature to control the creativity of responses, with values ranging from 0 (focused) to 1 (creative).
  • Select OpenAI as the AI to use and choose the model, such as GPT-5 Mini.
  • Enter your API key, which can be generated from the OpenAI platform.
  • Configure other settings like header and footer messages as needed.
By following these steps in Pabbly Chatflow, you will set up an effective AI assistant tailored to your business needs.
4. Customizing Your Chatbot Interface in Pabbly Chatflow
Once your AI assistant is created, it’s time to customize its interface. Within Pabbly Chatflow, you can adjust the appearance of your chatbot to align with your brand.
Choose the theme mode (light or dark) and select the assistant shape (circle, square, or rounded square). You can also set background colors and upload profile pictures for a more personalized touch.
  • Toggle on the active button to ensure your chatbot is live.
  • Embed the chatbot on your website for easy access.
  • Save all changes to avoid losing your customization.
Customizing your chatbot in Pabbly Chatflow ensures that it not only functions effectively but also represents your brand well.
5. Assigning Your AI Assistant to Contacts in Pabbly Chatflow
After setting up your AI assistant, you can assign it to specific contacts or groups within Pabbly Chatflow. Navigate to the “Inbox” settings to manage these assignments.
Select the AI assistant you just created and save the changes. This can be done for individual chats or bulk assignments for groups.
  • Enable AI auto replies for your contacts.
  • Select specific lists or all contacts for the AI assistant assignment.
  • Save the rules to finalize your settings.
This functionality in Pabbly Chatflow allows you to streamline communication and ensure that your AI assistant is effectively utilized across your contact base.
Creating a WhatsApp chatbot using Pabbly Chatflow is a straightforward process that can significantly enhance your business operations. By following the steps outlined, you can automate tasks typically handled by a receptionist, improving efficiency and customer satisfaction.
