1. Setting Up Pabbly Connect for Google Blogger
To automate sharing your new posts from Google Blogger to Facebook, you’ll first need to set up Pabbly Connect. This integration tool allows you to link various applications seamlessly, ensuring that whenever you publish a new blog post, it automatically shares to your Facebook page.
Start by logging into your Pabbly Connect account. From the dashboard, you can create a new workflow that will connect Google Blogger with Facebook. This is a simple process that will save you time and effort in sharing your content.
2. Connecting Google Blogger to Pabbly Connect
Once you’re in Pabbly Connect, the first step is to connect Google Blogger. Select Google Blogger as your application and choose the event as “New Post Added”. This will trigger the workflow whenever a new blog post is published.
Next, click on the “Connect” option and select “Add New Connection”. You will be prompted to sign in with your Google account. Make sure to choose the account linked to your Blogger profile. Once you grant access, you can proceed to save the connection.
  • Select Google Blogger as the application.
  • Choose “New Post Added” as the event.
  • Click on “Connect” and then “Add New Connection”.
After saving the connection, you’ll need to click on the “Save and Send Test Request” button to capture the latest blog post data from Google Blogger. This ensures that your integration is functioning correctly.
3. Setting Up Facebook Integration in Pabbly Connect
Now that Google Blogger is connected to Pabbly Connect, the next step is to set up the Facebook integration. Select Facebook Pages as the action application, and choose the event as “Create Page Post”. This will allow your new blog posts to be automatically shared on your Facebook page.
Click on the “Connect” button and select “Add New Connection”. You will need to log in to your Facebook account and authorize Pabbly Connect to post on your behalf. Once connected, select the specific Facebook page where you want the blog post to appear.
  • Choose Facebook Pages as the action application.
  • Select “Create Page Post” as the event.
  • Log in and authorize Pabbly Connect to access your Facebook account.
After setting up the connection, you can customize the message that will accompany the blog post link on Facebook. This message can include any relevant hashtags or descriptions to attract more readers.
4. Finalizing the Workflow in Pabbly Connect
With both Google Blogger and Facebook connected through Pabbly Connect, it’s time to finalize the workflow. You will need to map the data fields correctly. For instance, the URL of the new blog post should be dynamically linked to the Facebook post.
Click on the “Save and Send Test Request” button again to ensure everything is working. Once the test is successful, you should see a confirmation that the post has been created on your Facebook page. This means your automation is complete and functioning as expected.
Now every time you publish a new blog post on Google Blogger, Pabbly Connect will automatically share it on your specified Facebook page, saving you time and ensuring your followers stay updated.
5. Conclusion
Using Pabbly Connect to integrate Google Blogger with Facebook allows for seamless automation of your content sharing. By following the steps outlined above, you can ensure that your audience is always informed about your latest blog posts. This integration not only saves time but also enhances your online presence.
