To start automating Pinterest pin creation, access Pabbly Connect by visiting the official website. If you’re new, sign up for a free account to explore its features. You will receive 100 free tasks to test the automation capabilities.
Once logged in, navigate to the dashboard where you can create new workflows. The user-friendly interface allows you to connect various applications seamlessly, making it easy to set up your Pinterest automation.
In this section, you will learn how to create a new workflow using Pabbly Connect. Click on the “Create Workflow” option and select “Create Using AI”. This feature allows you to generate a workflow by simply entering a prompt.
  • Enter a prompt for generating Pinterest pins using Google Sheets.
  • Specify the details for the AI to create eye-catching images.
  • Approve and create the workflow to proceed.
After completing these steps, Pabbly Connect will analyze your request and prepare to connect to Google Sheets, which will act as the data source for your Pinterest pins.
3. Setting Up the Trigger in Google Sheets
Now, let’s set up the trigger in your Google Sheets using Pabbly Connect. Copy the webhook URL provided by Pabbly and open your Google Sheets. From the “Extensions” menu, go to “Add-ons” and select “Get Add-ons” to install the Pabbly Connect Webhooks add-on.
After installation, refresh your Google Sheets, go back to “Extensions”, and select the Pabbly Webhooks option. Here, you will need to paste the webhook URL and specify the trigger column where data will be entered. For instance, if you want to trigger on Column A, set it accordingly.
4. Generating Pinterest Pins Automatically
With the trigger set up, let’s generate Pinterest pins using Pabbly Connect. Enter a new idea in your Google Sheets. For example, add a description of a smoothie bowl. This will automatically trigger the workflow to create a pin.
After entering the idea, go back to your Pabbly Connect workflow to see if the trigger captures the new data. The response from Google Sheets will confirm the successful connection. Next, connect to Google Gemini to generate an image based on the description.
  • Use the API key from your Gemini account to connect.
  • Map the data from the previous step to create a high-quality image.
  • Send a test request to ensure the image is generated successfully.
Upon receiving the image URL, you can now create a pin on your Pinterest account using the generated image and description.
5. Updating Google Sheets with Pin Status
Finally, let’s update Google Sheets with the status of the generated Pinterest pin using Pabbly Connect. After successfully creating the pin, you need to reflect this in your Google Sheets. Connect to your Google account via Pabbly Connect and select the appropriate spreadsheet and sheet.
Specify the column where you want to update the status (e.g., Column B) and set the value to “Created”. This ensures that every time a pin is generated, the status in Google Sheets is updated automatically, providing a seamless workflow.
Now, whenever you enter a new idea in Google Sheets, Pabbly Connect will automatically create a Pinterest pin and update the status, streamlining your content creation process.
In this tutorial, you learned how to automate Pinterest pin creation using Pabbly Connect and Google Sheets. By following these steps, you can enhance your workflow and save time in generating content for your Pinterest account. Start using Pabbly Connect today to streamline your automation needs!
