To send bulk WhatsApp messages, the first step is to access Pabbly Connect. Start by navigating to pabbly.com/chatflow in your browser. This platform will enable you to integrate WhatsApp with your contact management seamlessly.
If you are a new user, sign up for a free account to receive 100 free credits, allowing you to test sending messages to at least 200 recipients. After logging in, you can set up your WhatsApp number within Pabbly Connect.
2. Creating Contact Lists in Pabbly Connect
Once you are logged into Pabbly Connect, the next step is to create a contact list for your customers. This is crucial for sending bulk WhatsApp messages efficiently.
  • Navigate to the Contacts section.
  • Create a new contact list by adding leads or customers.
  • You can also upload a CSV file containing your contacts.
Having a well-organized contact list is essential for effective communication. Once your contacts are set up, you can proceed to create message templates for your broadcasts using Pabbly Connect.
3. Creating Message Templates for Bulk WhatsApp Messages
In Pabbly Connect, creating a message template is a critical step before sending bulk WhatsApp messages. Go to the Template section to start this process.
Here’s how to create a new template:
  • Select the category as “Marketing”.
  • Name your template and choose the language.
  • Choose the type of template, such as image or text.
Once you submit your template, it will go through an approval process by Meta. If approved, you can use it for your broadcasts via Pabbly Connect.
4. Sending Broadcast Messages via Pabbly Connect
After setting up your template, it’s time to send out your bulk WhatsApp messages using Pabbly Connect. Go to the Broadcast section and click on the “Add Broadcast” button.
Here are the steps to follow:
  • Select your broadcast type (e.g., Broadcast Campaign).
  • Name your broadcast and choose your contact list.
  • Select the message template you created earlier.
You can also test the broadcast by sending a message to your own WhatsApp number before the actual broadcast, ensuring everything looks good. This testing feature is a great way to verify your setup within Pabbly Connect.
5. Scheduling and Sending Messages Through Pabbly Connect
Once your broadcast is set up, Pabbly Connect allows you to either send the messages immediately or schedule them for a later date.
To schedule your messages, follow these steps:
  • Choose the “Schedule for Later” option.
  • Set the date and time for your broadcast.
  • Confirm the scheduled broadcast in your account.
This feature is useful for planning your marketing campaigns in advance. On the scheduled date, Pabbly Connect will automatically send out your messages to the selected contacts.
In conclusion, using Pabbly Connect is the easiest way to send bulk WhatsApp messages. By following these steps, you can effectively communicate with your audience and enhance your marketing efforts.
