To start using Pabbly Connect, first, open a new tab and visit the official Pabbly website. Pabbly Connect serves as the central integration platform, allowing you to connect various applications seamlessly.
Once on the website, you can sign up for a free account to explore the features. This provides you with an opportunity to test Pabbly Connect and its capabilities without any initial investment.
2. Creating a WhatsApp Template in Pabbly Chat Flow
After logging into your Pabbly Chat Flow account, the next step is to create a WhatsApp messaging template. This template will be used for sending promotional messages to your customers.
  • Navigate to the template section in Pabbly Chat Flow.
  • Design your template with an attractive image and text relevant to your business.
  • Ensure the template is approved by Meta to avoid any issues.
Once your template is ready, you can use it for broadcasting messages. This is a crucial step in utilizing Pabbly Connect to enhance your communication strategy.
3. Setting Up a Broadcast with Pabbly Connect
To send bulk WhatsApp messages, you will use the broadcast feature in Pabbly Chat Flow. Start by clicking on the “Add Broadcast” button within your Pabbly Connect dashboard.
Here’s how to set up your broadcast:
  • Select the broadcast type as “Broadcast Campaign”.
  • Name your broadcast appropriately.
  • Choose your contact list from the options available in Pabbly Connect.
After selecting your contacts, you can either use the pre-approved template or create a new message. This flexibility makes Pabbly Connect an essential tool for managing your communications effectively.
4. Testing and Scheduling Your Broadcast
Before sending out your messages, it’s important to test how the broadcast will appear to recipients. Use the test feature in Pabbly Connect to send a sample message to your own number.
After testing, you can schedule your broadcast:
  • Select a date and time for the broadcast.
  • Toggle the automatic retry option for any failed contacts.
Once everything is set, click on “Add Broadcast” to finalize your settings. This ensures that your messages are sent out at the right time, maximizing engagement.
5. Conclusion
Using Pabbly Connect to integrate Pabbly Chat Flow with WhatsApp allows businesses to effectively manage their promotional messaging. By following the steps outlined, you can enhance your customer outreach efforts.
With Pabbly Connect, you ensure that your communication remains efficient and effective, providing value to your business and customers alike.
