To start integrating WhatsApp with Google using Pabbly Connect, first, log in to your Pabbly account. This platform is essential for connecting various applications seamlessly.
Once logged in, navigate to your dashboard. Here, you will find the option to add your WhatsApp number. Click on the “Add WhatsApp Number” button to proceed. Make sure to enter your WhatsApp number correctly to ensure proper functionality.
2. Creating an AI Chatbot with Pabbly Connect
Next, you will create an AI chatbot that responds to messages on WhatsApp. In your Pabbly dashboard, go to the AI Assistant feature and click on “Add AI Assistant”. This is where Pabbly Connect truly shines by allowing you to customize your chatbot.
  • Enter a name for your assistant.
  • Set the temperature for responses, influencing how predictable or varied the answers are.
  • Select OpenAI as your AI provider and choose the model you want to use.
After setting these parameters, Pabbly Connect will guide you through the next steps, ensuring your chatbot is ready for interactions.
3. Setting Up API for Pabbly Connect
For your AI chatbot to function, you need to set up an API key. Click on the link provided in Pabbly Connect to access the OpenAI API page. Log into your OpenAI account to generate a new secret key.
Once logged in, find the “Create New Secret Key” button. You will need to name your key and select a project, then click to create it. Copy this key and paste it back into Pabbly Connect to establish the connection.
4. Adding Knowledge Source for AI Responses
To enhance your AI chatbot’s responses, you must add a knowledge source. This involves creating a Google document containing your business details. Download this document in TXT format for optimal use with Pabbly Connect.
  • Upload the TXT file to Pabbly Connect.
  • Insert the knowledge base into the AI Assistant settings.
  • Ensure the AI Assistant can access this data to provide accurate responses.
By integrating this knowledge source, your AI chatbot will be able to answer customer queries effectively, making it a valuable asset for your business.
5. Finalizing Your AI Chatbot Setup in Pabbly Connect
After configuring the knowledge source, you need to finalize your chatbot settings. Customize the chatbot’s appearance, including colors and fonts, to match your branding. This personalization is easily done through Pabbly Connect.
Finally, click the “Save Assistant” button to make your chatbot live. Embed the provided script on your website to allow visitors to interact with your AI assistant. With this setup, every time a user starts a chat, the initial message will be sent from your WhatsApp number.
In this tutorial, we explored how to integrate WhatsApp, Pabbly, and Google using Pabbly Connect. This powerful platform allows you to create a responsive AI chatbot, enhancing customer engagement and support.
