1. Accessing Pabbly Connect to Start Your Automation
To begin using Pabbly Connect, first navigate to pabbly.com/connect. This powerful platform allows you to automate tasks without any coding skills. If you are a first-time user, sign up for a free account to receive 100 free tasks each month.
After logging in, you will be directed to the Pabbly Connect dashboard where you can create a new workflow. This setup is essential for connecting your applications seamlessly. By using Pabbly Connect, you can automate the creation of Pinterest pins daily with the help of Gemini AI.
2. Setting Up the Scheduled Trigger in Pabbly Connect
In this section, you will set up a scheduled trigger in Pabbly Connect to automate your workflow. Select the “Schedule by Pabbly” option to trigger actions daily. Choose the time you want the workflow to run, for example, 4:00 PM.
  • Click on the “Save” button to confirm your schedule.
  • Ensure that the workflow is set to trigger daily for consistent automation.
With the trigger set, every day at your chosen time, this workflow will automatically activate, setting the stage for the next steps in your automation process using Pabbly Connect.
3. Generating Content Using Gemini AI
Next, you will configure Pabbly Connect to connect with Gemini AI for content generation. Select the Google AI Studio as your application to generate recipe content. You will need to create a new connection by entering your API key from your Gemini account.
Follow these steps to generate the API key:
  • Go to the API key section in your Gemini account.
  • Generate a new API key and copy it for use in Pabbly Connect.
Paste the API key into the connection field in Pabbly Connect and save the connection. Now, you can input the text for Gemini to generate unique recipes, making your Pinterest automation even more effective.
4. Generating Images with Nano Banana
Once the recipe content is generated, the next step in your workflow involves creating an image using Nano Banana. This step is crucial as it provides a visual element for your Pinterest pins. Select the “Generate and Edit Image” option in Pabbly Connect.
Input the recipe generated in the previous step into the Nano Banana section. This will ensure that the image corresponds to the recipe created. After entering the details, click on the “Save and Send Test Request” button.
  • Map the data from the previous response to dynamically update the image based on the recipe.
  • After testing, you will receive a file URL for the generated image.
Copy the image URL and proceed to create your Pinterest pin using the generated image and recipe content, all facilitated by Pabbly Connect.
5. Creating a Pinterest Pin with Pabbly Connect
In this final step, you will use Pabbly Connect to create a new pin on your Pinterest board. Select the “Create Pin” option and choose the appropriate board for your pin. Fill in the details such as the image URL and the title of the pin.
For the title, you can use something like “New Food Recipe of the Day” and add a description based on the content generated earlier. Click on the “Save and Send Test Request” button to create the pin.
  • Ensure all fields are filled correctly before saving.
  • Upon successful creation, refresh your Pinterest board to see the new pin.
This finalizes your automated process of creating Pinterest pins daily using Pabbly Connect and Gemini AI, streamlining your content creation efforts.
In this tutorial, you learned how to automate the creation of Pinterest pins using Pabbly Connect and Gemini AI. By following the outlined steps, you can efficiently generate unique recipes and corresponding images, enhancing your Pinterest content strategy.
