To start using Pabbly Connect, simply log in to your account. If you’re new, take advantage of the free trial offered by Pabbly. This allows you to explore the features without any initial investment.
Once logged in, navigate to the workflow creator. This is where you will set up the integration between Pabbly, OpenAI, and Open AI. The user interface is intuitive, making it easy to follow along with the setup process.
To begin the integration, you need to set up a trigger in Pabbly Connect. Click on the “Add Trigger” button and select “Schedule” as the trigger type. Choose the event “Schedule Workflow” to specify when you want the workflow to run.
  • Select the frequency of the workflow (weekly, daily, monthly).
  • Set the exact time for execution, for example, 3:00 PM.
  • Click on “Save” to finalize your trigger settings.
After saving the trigger, you are ready to proceed to the next step, which involves setting up the action that will utilize OpenAI.
3. Integrating OpenAI with Pabbly Connect
Next, you will add an action in Pabbly Connect to integrate OpenAI. Click on “Add Action” and select OpenAI as the application. Choose “ChatGPT” as the event type, and then click on “Connect”.
To establish the connection, you will need an API key from OpenAI. Go to the OpenAI API keys page, create a new secret key, and copy it. Paste this key in Pabbly Connect when prompted, and click on “Save” to connect.
4. Creating Blog Content Using OpenAI
Once OpenAI is connected through Pabbly Connect, you can specify the model you want to use for generating content. For this example, select GPT-5. This model will generate content based on the parameters you provide.
Prepare the request by inputting all necessary details, including the content goals, target audience, and other relevant information. Ensure the request is formatted correctly, as this will determine the quality of the generated content.
  • Specify the format as JSON to receive structured data.
  • Include fields such as date, title, keywords, and summary.
After preparing the request, click on “Save and Send Test Request”. This will trigger OpenAI to generate the blog content for the specified days.
5. Adding Generated Content to Google Sheets
The final step is to add the generated content to Google Sheets using Pabbly Connect. Click on “Add Action” again, select Google Sheets, and choose “Add Multiple Rows” as the event.
Authenticate your Google account and grant the necessary permissions. Then, select the spreadsheet and worksheet where you want the data to be added. Use the dynamic fields from the previous steps to map the data correctly.
Ensure the data is organized in the correct order, following the sequence of fields you set up earlier. This will allow for a seamless integration of the generated content into your Google Sheets.
In this tutorial, we’ve demonstrated how to automate your blog content creation using Pabbly Connect and OpenAI. By following these steps, you can streamline your content generation process and save valuable time.
