1. Accessing Pabbly Connect to Begin Your Project
To start building your agency client portal, you need to access Pabbly Connect. Simply open a new tab and visit “pabbly.com”. Once there, you will find a “Sign Up Free” button for new users.
Existing users can log in directly. After logging in, you will see various Pabbly applications. Click on the “Access Now” button under Pabbly Studio to enter the dashboard. This is where your journey to creating the Nexora client portal begins.
2. Creating Your Application in Pabbly Studio
In Pabbly Connect, creating your application is straightforward. Click on the “Create Application” button. You will be prompted to name your application; enter “Nexora” and hit the “Create” button.
Once your application is created, you will be directed to the Pabbly Studio workspace. Here, you can input your application instructions. These instructions include elements like authentication, dashboard layout, and client management features. You can also define the visual identity of your application.
- Specify the authentication method
- Outline the main dashboard features
- Define client and project management capabilities
After pasting your instructions, click on the “Send Prompt” button. Pabbly Studio will begin analyzing your input and generating the application based on your specifications.
3. Overview of the Nexora Dashboard
Once Pabbly Studio completes the application, you will access the Nexora dashboard. The dashboard serves as a central hub for managing clients, projects, tasks, and deliverables.
The dashboard displays key metrics such as total clients, active projects, and upcoming deadlines. This allows agencies to quickly assess their workload without diving into each project individually.
In addition to metrics, the dashboard includes sections for recent projects and client activities. Users can also create new projects directly from the dashboard, streamlining workflow management. This integration is made possible through Pabbly Connect, ensuring all data is organized and accessible.
4. Managing Clients and Projects Effectively
Within the Nexora application, managing client information is essential. Each client can have details such as name, company, email, and phone number. This organization is facilitated by Pabbly Connect, which keeps all client data in one place.
For project management, each project includes vital information like project name, client association, description, start date, and priority level. The integration ensures that all project statuses are easily tracked.
- Create new client profiles
- Add project details and deadlines
- Track project progress and client interactions
With Pabbly Connect, the process of adding and managing clients and projects is seamless, enhancing overall efficiency.
5. Finalizing Your Agency Client Portal
After setting up client and project management, the final step is to customize the portal further. Users can preview how the application looks on different devices, ensuring a responsive design.
To share your application, simply click the share button to copy the link. You can also connect a custom domain if desired. This feature, powered by Pabbly Connect, allows for a professional presentation of your agency portal.
By following these steps, you have successfully created an integrated client portal using Pabbly Connect and Pabbly Studio. The portal is designed to streamline agency operations without the need for coding.
In this tutorial, you learned how to build an agency client portal using Pabbly Connect, Nexora, and Pabbly Studio without writing any code. This integration simplifies managing clients and projects, enhancing your agency’s workflow.
