1. Creating a WhatsApp Chatbot with Pabbly Connect
To create a WhatsApp chatbot, you will first need to access Pabbly Connect. This platform enables you to automate tasks and integrate various applications. Start by logging into your Pabbly account and navigating to the Pabi Chatflow section.
Once you’re in Pabbly Connect, you can set up the initial flow for your WhatsApp chatbot. This involves defining triggers and actions that will dictate how your chatbot interacts with users. Make sure to have your WhatsApp number linked to your Pabbly account for seamless integration.
2. Setting Up the Trigger for Your Chatbot in Pabbly Connect
In this step, you’ll define the trigger that initiates your WhatsApp chatbot. Using Pabbly Connect, select the trigger event to be a keyword match, like ‘hello’, which will start the conversation. This is crucial for ensuring that your chatbot responds appropriately to user input.
  • Choose ‘Keyword Regex Match’ as your trigger type.
  • Enter the keyword that will activate the chatbot.
  • Test the trigger to ensure it’s working as expected.
After setting up the trigger, you can proceed to design the welcome message that users will see when they initiate a conversation. This is a key part of your chatbot’s functionality, enhancing user experience.
3. Designing the Chatbot Flow Using Pabbly Connect
Now that you have your trigger set up, it’s time to design the chatbot flow. This is where Pabbly Connect shines, allowing you to drag and drop various action blocks to create the conversation flow. You can send welcome messages, ask questions, and provide options to users.
For instance, after the welcome message, you can add buttons for users to select options like booking a car. This interaction is essential for guiding users through the process. Here’s how to set it up:
  • Add a text block for the welcome message.
  • Create buttons for user actions, such as ‘Book Cars’.
  • Link these buttons to corresponding actions or messages.
By effectively designing the flow, you ensure that users have a seamless experience while interacting with your WhatsApp chatbot. This is a critical component of using Pabbly Connect efficiently.
4. Integrating Google Sheets with Pabbly Connect
Once your chatbot flow is designed, you can integrate Google Sheets to store user data. This is where Pabbly Connect facilitates the connection between Pabi Chatflow and Google Sheets. You’ll need to set up an API request to send data from the chatbot to your Google Sheet.
Begin by creating a new API request in your Pabbly Connect workflow. You will need to provide the Google Sheets webhook URL and define the parameters for the data you want to store, such as user name, rental duration, and pickup date.
Here’s how to do it:
  • Set up a new API request in your Pabbly Connect workflow.
  • Enter the Google Sheets webhook URL.
  • Map the data fields from your chatbot to the corresponding columns in Google Sheets.
This integration allows you to automatically save user responses directly into your Google Sheet, streamlining your data management process.
5. Finalizing Your WhatsApp Chatbot with Pabbly Connect
After setting up the integration, it’s time to finalize your WhatsApp chatbot. In this step, you will review all the components you have created within Pabbly Connect. Ensure that every part of the flow works as intended and that the data is correctly being sent to Google Sheets.
Finally, save your flow in Pabbly Connect. This is the last step to ensure that your WhatsApp chatbot is ready for use. Once saved, you can start interacting with your chatbot and see how it performs.
To conclude:
  • Review all chatbot messages and actions.
  • Test the integration with Google Sheets.
  • Save your flow and start using your chatbot.
This process demonstrates the power of using Pabbly Connect to create an efficient WhatsApp chatbot that can handle user inquiries and store data seamlessly.
In this tutorial, we explored how to create a WhatsApp chatbot using Pabbly Connect. By integrating Pabi Chatflow with Google Sheets, you can automate responses and manage data efficiently. This powerful combination enhances customer interaction and streamlines your business operations.
