1. Getting Started with Pabbly Connect
To begin, access Pabbly Connect by visiting the Pabbly website. This platform is essential for integrating multiple applications seamlessly. After signing up, you can create workflows that automate your tasks.
Once logged in, navigate to the dashboard. Here, you will find options to create new workflows. The integration process starts with selecting the trigger app, which will initiate the automation. In this case, you will set up Pabbly Chat Flow as your trigger.
2. Integrating Pabbly Chat Flow for WhatsApp Broadcasting
With Pabbly Connect, you can easily set up Pabbly Chat Flow for WhatsApp broadcasting. First, log into your Pabbly Chat Flow account. Ensure that your WhatsApp number is linked to this account for effective messaging.
  • Select “Broadcast” from the left menu.
  • Choose your broadcast type, such as “Globe Pure Offer”.
  • Identify the audience by selecting contact lists or uploading a CSV file.
This setup allows you to reach out to your customers effectively. Make sure to filter your audience to exclude any contacts that should not receive the broadcast.
3. Creating a Broadcast Message in Pabbly Chat Flow
After setting up your audience, you can create a broadcast message. Within Pabbly Connect, you have the option to send a regular message or a template message. If you choose a template message, ensure it is approved by Meta to avoid any delivery issues.
To create a template, navigate to the templates section and click on “Add Template”. Design your message, including images and text. Preview the message to ensure it appears correctly before sending it out.
  • Add images or other media to enrich your message.
  • Send a test message to verify everything is set up correctly.
Once you’re satisfied with the message, you can schedule it for immediate sending or for a later date.
4. Scheduling and Sending Broadcasts with Pabbly Connect
With your message ready, it’s time to schedule your broadcast. Within Pabbly Connect, you can select to send the message immediately or schedule it for a future date. This feature is crucial for planning your marketing campaigns effectively.
Choose the date and time you want the message to be sent. You can also enable automatic retries for contacts that fail to receive the message. This ensures that your broadcast reaches as many customers as possible.
Once everything is set, click on the “Create Broadcast” button to finalize your setup. You’ll receive a confirmation that your broadcast has been scheduled successfully.
5. Monitoring Broadcast Performance with Pabbly Connect
After your broadcast is sent, you can monitor its performance through Pabbly Connect. This allows you to see how many messages were delivered and any that failed to send. Access the statistics by clicking on the “View Statistics” button.
Analyzing this data helps you understand your audience better and improve future broadcasts. You can adjust your strategies based on this feedback to enhance engagement and response rates.
By leveraging Pabbly Connect, you can streamline your WhatsApp marketing efforts and ensure effective communication with your customers.
In summary, using Pabbly Connect to integrate Pabbly, Pabbly Chat Flow, and Pabbly Plus allows for efficient WhatsApp broadcasting. This process enhances communication with customers, especially during promotional events like Black Friday. Start utilizing these tools today for effective marketing strategies.
