1. Setup Your WhatsApp Assistant Using Pabbly Chartflow
For automating responses on WhatsApp, you need to set up a WhatsApp assistant using Pabbly Chartflow. This assistant will handle customer queries 24/7 without any manual intervention. By using Pabbly Chartflow, you can create a seamless experience for your hotel business.
Begin by logging into your Pabbly Chartflow account. If you don’t have one, you can sign up for free. Once logged in, navigate to the assistant section and click on ‘Add AI Assistant’. This is where you’ll name your assistant, for example, “WhatsApp Assistant for My Hotel”.
2. AI Configuration for Your Assistant
Now that you have named your assistant, it’s time to configure its AI settings using Pabbly Chartflow. For the type, select ‘AI Agent’ to ensure it functions correctly. Set the AI configuration temperature to 0.5, which balances focused responses with creativity.
  • Select OpenAI as the AI model.
  • Enter your OpenAI API key, which you can generate from your OpenAI account.
  • Enable header and photo messages for enhanced interaction.
After configuring these settings, ensure you save your changes. This setup is crucial for your WhatsApp assistant to respond effectively to customer inquiries.
3. Setting Up Knowledge Source for Your Assistant
For your assistant to provide accurate information, you need to upload a comprehensive knowledge source. This is where you detail your hotel’s services, prices, and policies. Using Pabbly Chartflow, click on ‘Add New File’ to upload your documentation.
Once uploaded, insert this document into your assistant configuration. This knowledge base will allow the assistant to answer questions like, “Do you provide airport pickup in Indor?” effectively. Ensure your knowledge base is detailed and clear to enhance customer satisfaction.
4. Activating Your WhatsApp Assistant
After setting up your assistant and knowledge source, it’s time to activate your WhatsApp assistant using Pabbly Chartflow. Toggle the activation button on and save your settings. This will enable your assistant to respond to customer inquiries automatically.
If you want to assign the assistant to specific contacts, navigate to the inbox settings. Here, you can select the contact list and enable the AI assistant for those users. This ensures that all incoming messages from these contacts will be handled by your assistant.
5. Testing Your Assistant’s Responses
To ensure your WhatsApp assistant is functioning correctly, conduct a few test queries. For instance, ask questions like, “Can I request a late checkout?” and observe the responses. The assistant should provide accurate answers based on the knowledge source you uploaded.
Testing is crucial before fully deploying your assistant. If everything works as expected, you can confidently use your Pabbly Chartflow assistant to handle customer inquiries, saving time and resources.
In summary, integrating WhatsApp with Pabbly Chartflow allows you to automate customer support for your hotel business efficiently. By following these steps, you can create an AI assistant that provides timely responses, enhancing customer satisfaction without the need for manual intervention.
