To create your AI agent for WhatsApp, the first step is accessing Pabbly Connect. This platform allows you to integrate various applications seamlessly, including OpenAI and Pabbly Chatbot.
Once you log in to your Pabbly Connect account, navigate to the AI Assistant feature within Pabbly Chatbot. Here, you can start creating different types of AI agents tailored to your business needs.
2. Creating Your AI Agent with Pabbly Chatbot
After accessing the AI Assistant feature, click on the “Add AI Assistant” button to begin. This action opens a new page where you need to name your AI assistant and click the “Add AI Assistant” button again.
  • Name your AI assistant
  • Select the type of instructions for the AI
  • Customize the AI’s behavior through instructions
This page will generate default instructions that dictate how the AI behaves. You can modify these instructions based on your specific requirements.
Next, you will need to configure the AI settings. This includes setting the temperature, which controls the creativity level of the AI’s responses. A lower temperature results in more stable responses, while a higher temperature yields more creative outputs.
For this tutorial, set the temperature to 0.5 and choose OpenAI as your AI provider. Make sure to select the appropriate version, such as GPT-4 Omni.
  • Set temperature to 0.5 for balanced responses
  • Select OpenAI as the AI provider
  • Choose the appropriate version, e.g., GPT-4 Omni
After this, you will need to enter your OpenAI API key. This key connects your OpenAI account to the AI agent on WhatsApp via Pabbly Connect.
4. Setting Up Your Knowledge Base
Now, it’s time to set up the knowledge base for your AI agent. This is crucial as it determines how well your AI can respond to queries. You can create a knowledge base using Google Docs or any other text-based application.
Once your knowledge base is ready, upload it to Pabbly Connect by clicking on the option to add a new file. Ensure that the file size does not exceed 90 MB for optimal performance.
  • Create a knowledge base document using Google Docs
  • Upload the file to Pabbly Connect
  • Ensure the file is under 90 MB
This knowledge base will empower your AI agent to provide accurate and specific responses to your clients’ inquiries.
5. Activating Your AI Agent in Pabbly Connect
Finally, after setting up your AI agent, you need to activate it. Click the save button to finalize your settings and make the AI agent live. You can also customize the design and interface of your AI agent to match your brand.
After activation, ensure that the option to allow the AI assistant to respond to chats is enabled in the settings. This will ensure that your AI agent can interact with clients effectively.
Once everything is set, your AI agent is now live on WhatsApp, ready to assist your customers. This integration showcases the power of Pabbly Connect in automating business processes through AI.
In this tutorial, we walked through the process of creating an AI agent for WhatsApp using Pabbly Connect, OpenAI, and Pabbly Chatbot. By following these steps, you can automate your customer interactions efficiently and effectively.
