To create an automated WhatsApp assistant, you first need to access Pabbly Connect. Simply open a new tab in your browser and type in ‘pabbly.com’. Once there, navigate to the Pabbly Connect section.
For new users, click on the ‘Sign Up’ button to create an account. Existing users should click on ‘Sign In’. After signing in, you can start setting up your WhatsApp assistant.
2. Connecting Your WhatsApp Number in Pabbly Connect
Once you are logged into Pabbly Connect, the next step is to connect your WhatsApp number. Navigate to the ‘Add WhatsApp Number’ section. Here, you can choose the preferred method to link your WhatsApp account directly to Pabbly.
- Click on ‘Add WhatsApp Number’.
- Follow the prompts to connect your number.
- Verify your number through the provided method.
After connecting your number, you will be able to automate responses through your WhatsApp assistant, making it easier to handle customer inquiries.
3. Creating Your WhatsApp Assistant in Pabbly Connect
Now that your WhatsApp number is connected, you can create your AI assistant using Pabbly Connect. Click on the ‘Add Assistant’ button to start this process. You will be prompted to name your assistant. For example, you can name it “New AI Assistant”.
Next, you will need to set the configuration for your assistant. Choose the type of AI agent you want to create. You can specify instructions for how the assistant should respond. Additionally, you will set parameters like temperature to determine the creativity of responses.
- Select ‘AI Agent’ as the type.
- Set the temperature value for response creativity.
- Connect the OpenAI API for response generation.
By configuring these settings, your assistant will be ready to handle customer queries effectively.
4. Finalizing Your WhatsApp Assistant Setup in Pabbly Connect
After setting up the basic configurations, it’s time to finalize your assistant in Pabbly Connect. You can add additional settings like header and footer messages or fallback messages for when the assistant cannot respond.
Upload your knowledge source file, which can be in PDF or TXT format. This file should contain all necessary details about your services. Once uploaded, your assistant will use this information to respond to customer queries accurately.
- Add header and footer messages as needed.
- Upload your knowledge source file.
- Ensure all settings are saved properly.
After completing these steps, your WhatsApp assistant will be ready to engage users automatically.
5. Assigning Your WhatsApp Assistant in Pabbly Connect
The final step is to assign your newly created assistant in Pabbly Connect. You can assign it to specific chats or enable it for all contacts. To do this, navigate to the settings section and find the inbox settings.
Enable the AI auto-reply feature and select your assistant. This will allow the assistant to respond to any incoming messages from your contacts. You can choose to assign it to all contacts or just specific ones.
- Go to inbox settings.
- Enable AI auto-reply.
- Select your assistant and save the settings.
Once this is done, your WhatsApp assistant will be operational, ready to assist your customers 24/7 without manual intervention.
In this tutorial, we demonstrated how to use Pabbly Connect to create an automated WhatsApp assistant quickly. By following these steps, you can streamline customer interactions and enhance service efficiency.
